The seats in my car had been previously swapped to black and red ones from an RX8 (Jamie N's old car) but to be honest I wasn't a huge fan of them bit too large for my liking and unable to go far enough back for comfort so decided to swap them for something more appropriate (in my eyes).
Bought a set of black MX5 Mk2/2.5 seats which although heated are not motorised like the RX8 seats but that was never high on my agenda. Removed the RX8 seats and I was surprised to see how much smaller and lighter the MX5 ones are even compared to the non motorised RX8 passenger seat.
Loosely put the MX5 seats into the car and what a difference narrower and shorter with more room behind to go further back and still miss the B Pillar and the runners are much closer to the original Lotus mounts than the old ones. Had to swop the seat belt clips as the Elan belt buckle doesn't lock into an MX5 one but simple to do.
Just waiting for some MS flat bar, bolts, washers etc. to arrive so I can get them fitted properly hopefully this weekend looks from first measurements I can fit them to go quite far back and still recline using different width brackets mounted to the original seat bolts, 100mm at the front and 150mm to the rear this should allow enough adjustment to get the seats where I want them in distance and height.
Also took the opportunity to replace the passenger seat belt assembly which had stopped retracting and was looking worse for wear with a 2nd hand Elan one from eBay which to be honest looked almost like new, easy job B pillar off, speaker box out and 4 bolts 20 minute job as all the bolts came out easily.
Once I get the material to finish the job I will take some pictures.
Also now have the RX8 seats surplus if anyone wants them for £50 collection only for the pair, drivers motorised and was working on Saturday. can't seem to get pictures to work but I can send them if anyone interested.
