They are item 30.
Rambo wrote:I have taken a photo but can't resize the image at present as picresize is playing up![]()
Available from SJS incidentally
Fredjohn wrote:SJs require you to submit an enquiry for a quotation, which probably does mean it isn't available. It only appears if you do a complete database search, ie don't restrict search to M100.
Jamie N wrote:Mark, if its the complete switch you need you can get ones from a Corsa C (2000 on) ,and after a very simple mod they will fit straight
into your centre console, and I can tell you this...they work and sit better than the originals, I posted about them on here a while back
but money saving mods on here are often ignored.
This is them fitted, they cost £1 each from the salvage yard, or you could buy a pair of the hundreds on ebay for very slightly more.![]()
CallMeLegend wrote:Nice, how about the electrical connectors? Were they the same?
dapinky wrote:If you're were only a quid each I was robbed - I paid £8 for a pair (delivered) from fleabay.
par wrote:I have a couple of these Corsa type switches supplied by Jamie here which I can send on if wanted.
They are complete with connector and pigtail wiring and even comes with an original freehand wiring diagram on the back of a disposable glove box by the master of seals himself![]()
I had intended to fit these on mine but I have plenty of other things to work on at the moment so happy to send on if wanted.
