RonR wrote:Another lock-down pastime for me was trying to calculate the prop valve O-ring sizes.
I used the O-ring calculator Here
Here's what I came up with for what it's worth:
Rambo wrote:I think Jim (Muley) has done some work on proportioning valves in the last year or so. I think he eventually replaced them
Also, I'm fairly sure Dapinky has some useful info re. prop. valves
Some other info here....viewtopic.php?f=41&t=23606&p=353877&hilit=Proportioning+valves#p353877
RonR wrote:I didn't have access to the original specs. Measurements came from a dismantled good condition spare, also from a new Vauxhall 3/45 valve which uses the same centre section but different ends, piston and spring. The piston and cylinder measurements were put into the calculator, then I tried various o-ring sizes until the stretch and squash figures met the specs for the fluid and o-ring material.
A note of CAUTION: I'd say the BS904 is VERY marginal, once it's stretched over the piston it will only compress by ~1.4% in the cylinder, while the calculator recommends 10% or greater. I'd expect to see fluid leakage past the seal when under pressure.
I haven't gotten to the coolant hoses yet, but I'm betting there is going to be a Samco purchase in my future.TorqueHorse wrote:Finally got a look at the decrepit strap that was holding the coolant tank in place. I haven't seen this in many other folks' engine bay photos. Don't think I'll be able to save it though. Anyone have thoughts on their favorite replacement for these?
TorqueHorse wrote:There is going to be sooooo much cleaning once this thing is outI haven't gotten to the coolant hoses yet, but I'm betting there is going to be a Samco purchase in my future.
Don’t throw away the old strap, you can re-use the ends, bend the staples back and remove them, then buy the multi hole bungy strap...
Ohhhh, not just cleaning. You also have media blasting, powder coating, chassis derusting, power steering pipe replacement, UJ regreasing, alternator and starter overhaul and all sorts of other exciting things to look forward to. Having the engine out makes it so much easier to indulge in scope creep![]()
No, I'm drawing the line at the suspension and steering rack this go. But, maybe I could... TorqueHorse wrote:Seriously though, what symptoms made you think you needed to work on starter or alternator?
It's a long story...
