Window Upstop Bobbins & Tapping Plates
Re: Window Upstop Bobbins & Tapping Plates
Postby Fredjohn » Thu 20.08.2020, 17:53
Brit-Car-Nut wrote:Isn't that what I said?
"Nothing should be bonded to the glass, not even the plastic washer."
Yes John it is. Just reiterating it in case John (tb10) or others missed it.
Sorry, should have given you acknowledgement for your comment.
Postby tb10 » Fri 21.08.2020, 09:20
Sorry, M’lud!
I was merely requoting what the witness said in the first instance. There was no attempt to misled or misrepresent the witness or indeed the Part 25 expert. I was aware of what was latterly said from across the pond. ;-)
However, the question of bondage, or otherwise, perhaps needs to be considered on an alternate forum as it is clear that there shouldn't be any bondage at all in this instance :shock:
Regards to all!
:cheers:
tb10
Postby Fredjohn » Fri 21.08.2020, 10:19
OK John explanation accepted. CPS will not follow this up.
See you Sept??
:cheers:
Postby tb10 » Fri 21.08.2020, 10:27
Fredjohn wrote:See you Sept??
:cheers:
Yes, I think so as I'm very thirsty ...... :gathering:
tb10
Postby CallMeLegend » Fri 28.08.2020, 20:10
I have found these M5 nut plates, they are a bit smaller than the regular tapping plates, but it's given me an idea.
CallMeLegend
Postby CallMeLegend » Fri 28.08.2020, 21:01
I have found a nice solution.....
Little 3d printed shim to spread the load.
Then a 3d printed bobbin so the sizes all match
This utilises the off the shelf nutplates that are a good chunk cheaper than the tapping plates
Total thickness of the nutplate & shim is 2,25mm
CallMeLegend
Return to Interior
