by djwazza68 » Sun 06.12.2020, 21:45
I’ve been looking at the wind deflector options for the Elan and I’m coming up with either a bolt in mesh panel or a make my own polycarbonate one. What I’m after is a removable folding option for something like a modern German car:
https://www.ebay.co.uk/itm/BMW-6-Series ... SwbVVfq6T9 As anyone fitted such a system and if so can they point me at the correct type? I’m keen not to damage the car and to just fit a couple of simple brackets to hold the system.
Thanks in advance
djwazza68
- Tinkerer
by Rambo » Sun 06.12.2020, 22:06
Lots of stuff on wind deflectors if you use the search facility (top RHS)
Here's one solution
viewtopic.php?f=80&t=27729
- Don't push me
by djwazza68 » Sun 06.12.2020, 22:45
Thanks for the info, I’ve already done the search of this site; hence my comment regarding polycarbonate deflectors and mesh affairs, ie the link you posted.
I’m after a fully removable system that simply clips in and can be removed, folded up and stowed in either the boot or behind the seats. From your comment I assume that is something no one has either considered, or posted yet?
djwazza68
- Tinkerer
by djwazza68 » Sun 06.12.2020, 23:09
It looks like the foldable variety are likely to be too specific to the cars they are meant for, the ones that Classic Additions and Weyer make seem to all be bolt on items ahead of the rear pocket. Nevertheless Amazon seems to have a Weyer one available at £85.
Thanks for the help Rambo.
djwazza68
- Tinkerer
by Rambo » Mon 07.12.2020, 10:41
The best design I've seen by an LEC member was the AERWD (Andrew Ennis Retractable Wind Deflector) it basically worked like a blind made of mesh but in reverse. It was fairly unobtrusive ie could be rolled away when not in use and could easily be removed
The design can still be seen on a few Scottish cars (AE was a design engineer based in Aberdeen) ie John Wham's pacific blue one. And I think ScottJ (now Par's) car also had one fitted
- Don't push me
by djwazza68 » Sun 10.01.2021, 16:39
I’m about to try a Peugeot 207cc removable deflector for size, it looks like it should fit behind the seats without much modification. Has anyone tried using one of these before?
Edit: don’t bother it is fractionally too large in both width and depth and mounting it would have meant some serious hole cutting into the structure.
djwazza68
- Tinkerer
by djwazza68 » Wed 13.01.2021, 00:43
I managed to find a Weyer wind deflector on Amazon for £54 delivered which turns up in a couple of days; hoping to create a similar system to that used on the polycarbonate screen, which means I can stow it behind the seats quickly. Update to follow.
Now fitted in a matter of minutes and looks very smart. Once I get a chance to drive in decent weather with the top down I can see if it has made any difference to the buffeting experienced at speed.
djwazza68
- Tinkerer
by CalElan » Fri 15.01.2021, 02:45
Do you have a link?
CalElan
by Rambo » Fri 15.01.2021, 10:48
From memory, Pinky (Dave Pink) has a neat polycarbonate wind deflector. I suspect that Dave made it himself
- Don't push me
by dapinky » Fri 15.01.2021, 11:21
Rambo wrote:From memory, Pinky (Dave Pink) has a neat polycarbonate wind deflector. I suspect that Dave made it himself
I do, but I didn't!
It came with the hoops, and was designed and made by the Goddess herself as part of the package.
- LEC Administrator
by Rambo » Fri 15.01.2021, 21:57
Oh aye, LGM
- Don't push me
by djwazza68 » Fri 15.01.2021, 22:03
djwazza68
- Tinkerer
by alan e » Sat 16.01.2021, 08:52
A lot of us have this wind deflector fitted to our cars it works very well and is easy to fit, no need to remove it when putting the roof up and down.
2010 black evora
Austin 7 1932 box saloon
MG ZS EV
alan e
