UK SE Register
Re: UK SE Register
Postby Specky » Mon 15.03.2010, 17:28
If you use the last four numbers of your VIN and look at This it will narrow it down to a month.
If you want to know more about your car, contact Hethel archives direct and obtain a certificate of provenance (£25 when I got mine).
They hold the cars build book on record,
Here's an example of one of mine
Hope that helps
Re: UK SE Register
Postby chipp » Mon 15.03.2010, 17:39
that was easy, first of the line in may 1992
chipp
92SE written off
95S2 sold
91SE sold
chipp
Re: UK SE Register
Postby chipp » Tue 30.03.2010, 18:50
chipp wrote:hi phil, just gathering together some info on my 92se for your register. how can i obtain the build date from the imformation i have with the car?
also i dont know of hand what might be an extra, is there somewhere i can find an extras list for this year?
chipp
phil, i sent you a PM. did you get it , i've not had a reply.
chipp
92SE written off
95S2 sold
91SE sold
chipp
Re: UK SE Register
Postby surfboardfiller » Fri 09.04.2010, 18:08
chipp
chipp
Thanks Chipp, been really busy at work and didn't reply! :roll:
Thanks for your help in adding your car, it's much appreciated.
surfboardfiller
Re: UK SE Register
Postby texas2201 » Mon 31.05.2010, 12:31
Colour - Silver Frost
Leather Type: Half with some sort of plaid/check material
FactoryExtras:
Mileage: 120,240
Engine Number
Chassis Number/VIN
Build Date 1989
Registration Number MUI 2382 formerly G751JSF
Date Of 1st Registration 1989
Registration District -
Owner - Martin Houston
Insurance Write Off? No
Status: On the road
Comments: Wilwood front brakes, Bob's rear brakes and hub, rebuild, resprayed, everest chip, lambda sensor, peco exhaust, new rear drop links aka Bob, new head gasket, water pump, cambelt,
Re: UK SE Register
Postby Breed » Thu 19.08.2010, 23:54
Steel Blue SE (think it is steel blue it looks like a grey with a hint of blue)
Reg J970 SPH
One owner in Lingfield, Surrey.
Mileage just over 25,000
Owner does not have a computer so might not be on register. If not I will have a chat with him to see what other info I can get.
Bill
Breed
Re: UK SE Register
Postby WienLot » Sat 10.11.2012, 22:28
Phil, I sent you a PM to know how to access and complete the database with details of my car. did you get it , i've not had a reply.
Br
WienLot
Elan SE turbocharged 1991
1) “ If it works, don't fix it ”
2) Never give up...!
WienLot
Re: UK SE Register
Postby surfboardfiller » Wed 21.11.2012, 17:32
Sorry I took so long to get back to you Franck.
surfboardfiller
Re: UK SE Register
Postby Fredjohn » Wed 21.11.2012, 23:53
Are you still collating UK SE info onto a database? If so I will PM you my car details.
I only got it in August: it had 3 previous owners (I know all their names if not current location!) and is still on its original plate. It's gradually working its way south, having started road life in Scotland, it's now in Warwickshire. So it will be easy to check if you have it already, but under a previous owners name.
Re: UK SE Register
Postby surfboardfiller » Thu 22.11.2012, 02:46
If it's in the database I can find it by Reg or VIN but there are a lot of gaps to fill and a lot of cars missing.
PM me the details if you can.
Thanks,
surfboardfiller
Re: UK SE Register
Postby munch power » Tue 08.10.2013, 19:40
blue ,h708 atv .elan se
munch power
Re: UK SE Register
Postby BarryDalHerbert » Wed 30.03.2016, 12:51
I have an Elan, but it far from being ready to drive, and is 200 kms away, so I can't just pop outside and gather the information. I will get it together and send it to you though.
And since the buy-it, buy-it, buy-it part of my brain is soon taking me to look at an Elan that actually is running, I'll get all the details of that too. This is what I know about that car at the moment: viewtopic.php?f=21&t=25116 if you have anything in the register I'd like to hear!
Many thanks
BdH
Canberra, Australia
Wed 30-Mar-16 22:51
BarryDalHerbert
Re: UK SE Register
Postby clemo » Fri 01.04.2016, 17:36
BarryDalHerbert wrote:I have an Elan, but it far from being ready to drive, and is 200 kms away, so I can't just pop outside and gather the information. I will get it together and send it to you though.
Many thanks
BdH
Canberra, Australia
Wed 30-Mar-16 22:51
Hi Barry ...
Sorry i can't shed any light on your car but i too have a similar scenario . My SE is in a shed and i haven't seen it for 5 years !. i remember its red .
clemo
Re: UK SE Register
Postby kevinrooney » Thu 08.12.2016, 12:03
who do I send on details of my car to for updating the register ?
Kevin.
kevinrooney
Re: UK SE Register
Postby Dave Eds » Thu 08.12.2016, 12:55
See the first post on the thread Kevin.
Re: UK SE Register
Postby DAGDA 564 » Sun 18.10.2020, 22:28
Bonjour,
J'ai acheté une Lotus Elan M100 SE il y a quelques mois, mais je me demande quel est son numéro (ordre ) de fabrication ??? pouvez vous me dire comment savoir c'est la combien sur 3800 ?
Merci d'avance
Benoît
DAGDA 564
Re: UK SE Register
Postby Blaster » Wed 17.02.2021, 16:40
Is this still be kept up to date.
Tony
1990 Lotus Elan SE 2009 Triumph Daytona 675SE
2012 KTM Freeride 350 2008 VW T5 4-Motion camper.
1995 Defender 300TDi 2012 Ducati Hypermotard
2018 AC Nitro 200 and Dudek Solo wing
Blaster
Re: UK SE Register
Postby LotusRescue » Fri 01.04.2022, 22:40
Hi Phil.
As LotusRescue, I currently have 2 cars. One being a 92 SE which I have rescued after being partially abandoned 10 years ago. As far as I can tell, she was exported not long after being 1st registered, the re-imported in 2000. At this point she was made a cat N write off, bought back and repaired. Originally Red, she was changed to Yellow. Registration number is J29 KHY. to date I have had a new screen fitted as the original was smashed, apparently a roof tile went through it about 5 years ago. The car had a fantastic covering of moss, leaves and other debris, but is now looking great after some deep cleaning and a machine polish. Now fully serviced, new exhaust, cat, brakes, tyres and a host more new parts. Presently still having minor electrical issues which is preventing her from getting a new MOT as the emissions are sky high. The second car I have is an N/A, this one had also been abandoned after the previous owner getting a huge bill for repairs and still failed to get an MOT. Purchased by me as a none starter. Simple fix as the fuel shut off had been activated. Now requires finishing off which will include a new drivers door window (broken) ball joints and brake imbalance fixed. Registration of the Metallic Blue one is. No H 185 XCK.
John.
LotusRescue
Re: UK SE Register
Postby PaulM » Sat 06.05.2023, 05:56
Good morning. Are you still doing this and if you are, do you have J770BCL yet?
Paul.
PaulM
Return to General
Users browsing this forum: AhrefsBot and 5 guests
