squealing cooling fans
Re: squealing cooling fans
Postby clemo » Mon 02.10.2017, 20:23
i put an inline switch to the dash as an override so if / when sitting in traffic i don't have to wait for the car to heat up before fans kicking in .
This too allows me to regularly feed the fans with power to rotate .
clemo
Postby Rambo » Tue 03.10.2017, 14:18
I have that set up in the Black Beastie Clemo. It's great for when you get stuck in town and also on the motorways. You can bring the fans in early before the needle nearly hits off the top of the temp. gauge :?
Postby HJ2 » Tue 16.03.2021, 14:27
I now have one broken fan on the steel blue :?
(squeels like a pig) Did anyone ever attempt to replace bearings?
What is the latest insight on replacement parts ?
Both need to work on the fan switch, but which one is operated by the aircon?
Postby Simon_P » Tue 16.03.2021, 16:07
They are bronze bushes and have dried out - Drill a small hole in the side of the raised part and inject oil.
Both work for aircon it just switches the fan relay.
Postby HJ2 » Tue 16.03.2021, 16:09
Can you press them out and boil them in oil?
Another question as i am troubleshooting currently: When i ground the fan switch on the thermostat housing, and the contact is on, one or both fans should rotate, right?
How is that with the aircon?
Edit: Must read better...
Somehow I get only 12 V on one fan, and even that one does not run. When I switch the connector from left to right fan, that fan also does not work... 2 broken fans? :shock: :?
Postby GeoffSmith » Tue 16.03.2021, 20:33
Or bad earth.
Postby HJ2 » Tue 16.03.2021, 22:24
Indeed. Should there be galvanic contact on the negative pole in the fan connector?
If so, I can make a temp. connection to check...
Postby Rambo » Wed 17.03.2021, 10:31
HJ2 wrote:What is the latest insight on replacement parts ?
I don't know if this helps HJ but SJS have these in stock. Supply, VAT and postage may be prohibitive though :roll:
https://www.sjsportscars.com/parts-and- ... 0K0003.htm
PS The last time I changed a fan was my Collapso Red Rambo and I'm sure the make was Valeo so possibly another source for you?
See also here for any further info http://wikilec.com/view/Cooling_Fans
Postby HJ2 » Wed 17.03.2021, 10:46
Thanks!
Trouble shoot first, then see if I can repair and if not look for a replacement :-)
Postby Simon_P » Wed 17.03.2021, 12:50
HJ2 wrote:Indeed. Should there be galvanic contact on the negative pole in the fan connector?
I think the answer to your question is yes; both + and - are supplied through the plug. From the plug follow the wire up to the top part of the frame where ist is grounded with a small screw.
Postby HJ2 » Wed 17.03.2021, 20:07
So... I had 2 problems with 2 cars with at least 2 fans!
1.
On my own car, both fans did not operate anymore. Fan switch worked, fuses OK, Relais OK, Wiring OK, but ground of both fans was not connected to chassis properly apparently.
Simon, you were spot on! I emptied my socket extension bin and after a while I was able to fix a new (self locking) bolt. Man is it a tight space in that corner!
The fans now both jump to life when shorting the fan switch, be it one squealing like a pig as well! After a second or 2 it went quiet again. Mission accomplished 8)
It turns out this was (one of the) reasons why my air conditioning compressor locked up. hopefully 3 problems solved with one screw! (Did I thank Simon already? :lol: )
2.
Squealing fan on steelblue:
Need to remove Fan first to see what I can fix :-D
Postby GeoffSmith » Wed 17.03.2021, 21:10
GeoffSmith - Tue 16.03.2021, 20:33 wrote:Or bad earth.
HJ2 wrote:So... I had 2 problems with 2 cars with at least 2 fans!
1.
No need to thank me. Oh, you didn't… that's OK then. :twisted:
Postby HJ2 » Wed 17.03.2021, 22:05
Mea culpa maxima! :bonk:
Postby GeoffSmith » Wed 17.03.2021, 22:47
:lol:
Postby Simon_P » Fri 19.03.2021, 19:29
I thought HJ's "indeed" was proportionate to your comprehensive suggestion - You want thanks as well? :roll:
Postby GeoffSmith » Fri 19.03.2021, 20:41
Indeed I do. :lol:
Postby HJ2 » Tue 23.03.2021, 13:50
I am still left with 2 fans that need replacement.
It would be great if anyone has a link to a universal one that fits without additional custom brackets (Bolt Pattern identical to OEM)
Or perhaps you have 2 pcs wandering about since the last groupbuy that will not be used?
Soldering the connector is not a problem :-)
Any pointers would be appreciated!
Postby GeoffSmith » Tue 23.03.2021, 22:56
Gordon found a good replacement a few years ago and John gives a link on the last post (2020). The Wiki has some information and if you want me to talk to Gordon or John, then I can do on the dark side. But you'll have to ask me nicely. :twisted:
Postby HJ2 » Mon 29.03.2021, 18:41
OK... I'll ask nicely.
Will the dark side approve his please?
https://www.ebay.co.uk/itm/Motorsportlu ... Swqu9VRmX6
8)
I'm too tired to select a decent replacement, so could do with a direct order link pretty pretty please Geoff :-)
Postby Fredjohn » Mon 29.03.2021, 18:51
How about these HJ?
rad fans
