Simon_P wrote:they are designed not to be undone. The nut is a special locknut that jams in the thread when you try to undo it.TorqueHorse wrote:I used coppereze on all the threaded mechanical fasteners, because getting them off the first time was hard enough.
par wrote:Some great work going on here.
It has been decades since I lapped valves, seriously tedious but rewarding at the same time
378S2 wrote:Lovely to see - solid progress. Are you going to pull the bottom end apart and change the rings?...
Grrrr, now I'm going to have to look at what SJ has. I really need to stop posting here, or I'll never finish
about £2k and the parts to do it properly like graded bearings aren't available.378S2 wrote:I want to see what it takes!
...an inspiration for my next job, when Steel Blue is finished: Engine revision
This one is designed not to wear out so you are unlikely to need a rebore and new pistons...
378S2 wrote:What causes the pistons to wear like that?...
378S2 wrote:Love the photo of the dishwasher...[did] you put the dishes in as well?
Simon_P wrote:Your bore measurements don't look quite right - they are smaller than the new grades!
Simon_P wrote:Id check the oil jet for the piston on the right and also that the hole in the bearing shell was in the righ place. Aftermarket bearings don't have the hole so you have to make one.
If you are looking for pistons don't forget that the Lotus ones are forged and different from the N/A
Simon_P wrote:I can smell your diswasher from memory!
Right? I pretty much spent all yesterday doing the measurements, multiple times per bore and pistons with the same set of gear, and figured if its wrong, at least it is consistently wrong, and that the relative measures are the most important takeaway.
