Hood Seals...The latest design.
Postby Jamie N » Thu 16.05.2019, 18:10
Another change to the status quo. Along the lines of making the header seal and A pillar seals all one, I have now done the same with the Intermediate and the forward seal on the side of the hood and made them into one. Well how is that going to work I hear you say!, absolutely simply I reply. :D
We all know that one of the main reasons the originals seals split apart is because of the contact they make with each other as the hood opens and closes, which due to the design of the hood is pretty much unavoidable, therefore the only real solution is to not have seals folding over the top of each other, hence we now have 'quick release' hood seals.
Unclip both of them, (takes seconds) store behind the seat or put in the boot, and watch the hood go down much more easily than if it had seals on it, but now with no damage being done to them. Bring the hood back up into position, clip the seals back in place and close the latches, that's it, absolute simplicity, but highly effective and takes no more time than time saved jumping up and down pushing on the hood in order to close the cover.
The other benefit of this style is it looks fantastically neat and tidy, no messy burst join in the middle (another source of leaking) and the finish right the way round the hood and down the A pillars is brilliantly clean and smooth, the transformation all of these seals make to the car really has to be seen for real, pictures will give you an idea but standing beside it is really the only place you can fully appreciate it.
Of course the number one priority with seals is waterproofing, and this setup now is about as good as I can get it, the hose test showed no ingress at all anywhere. This is the setup I will be using from now on, I wouldn't go back to the separate seals .
Its certainly different.
Once the glass is tucked up into these its as watertight as any modern convertible.
The usual scenario at the bottom, fit for the bin. ;-)
Monaco S2 #406
Jamie N
Seal God
Re: Hood Seals...The latest design.
Postby HJ2 » Thu 16.05.2019, 19:36
:bowdown:
All kneel for the seal wrangler!
Postby alan e » Thu 16.05.2019, 20:11
Jamie i have your all in one header seal (not fitted yet) but how much is your new seal and do you have any made up it will be good to show it CC next weekend.
2010 black evora
Austin 7 1932 box saloon
MG ZS EV
alan e
Postby lotusrepair » Thu 16.05.2019, 20:16
I am also interested in this seal. How does it work with folding of the hood?
lotusrepair
Postby Kipperozzy » Thu 16.05.2019, 21:15
Hi Jamie, the one piece seal certainly looks the part, and I imagine the smoothness also eliminates wind noise which I sometimes get from my join.
You will need to post some more detailed photos , I’d like to se how it fixes onto the frame and tight to the b post and header seals, looks like a great mod. :clap:
Kipperozzy
Postby alan e » Thu 16.05.2019, 21:19
lotusrepair wrote:I am also interested in this seal. How does it work with folding of the hood?
If i am reading it right you remove the intermediate and forward seal which clips into place and is one seal no joints when you fold the hood down and when you lift the hood up you refit the seal again it clips into place before fixing the hood down. Pure genius in it's simplicity.
2010 black evora
MG ZS EV
alan e
Postby TrevorB » Thu 16.05.2019, 22:41
alan e wrote: Pure genius in it's simplicity.
:clap: :clap: Well done Jamie
HiSpec front brakes
PNM rear brakes
Aluminium radiator
Closed Loop conversion
Kilimanjaro chip
Wannabe Princess
Postby LRS7 » Thu 16.05.2019, 23:08
Outstanding work Jamie hopefully you’ll bring them to CC to show them off .. I’d love to see them :D
Range Rover Vogue
Range Rover Evoque
Lotus Exige S2
Suzuki Bandit
LRS7
Postby Fredjohn » Fri 17.05.2019, 09:39
LRS7 wrote:Outstanding work Jamie hopefully you’ll bring them to CC to show them off .. I’d love to see them :D
Yes it would, but I don't think he's coming. Scottishland is way up north I'm told!
Postby Rambo » Fri 17.05.2019, 18:56
And Nicola Sturgeon won't renew his passport :( He is stuck in the toxic metropolis of Rawshyte in the Kingdom of Fife forever :lol:
If only he had developed this seal earlier I could have modelled the prototype and bought it down with me :(
Postby NewLogik » Sat 18.05.2019, 04:22
Very interested too. Seems like a really good solution ! :)
NewLogik
Postby Elanlover » Sat 18.05.2019, 14:47
As am I (interested that is). Planning another run soon? :-D
Postby Jamie N » Sat 18.05.2019, 20:55
I only have 2 sets of these at the moment, the ones I am using and the other for my relatives Elan. I should be able to do a small amount
but its the time factor and these ones take a fair bit of that. The other thing to note is that these seals are matched to the one piece Header / A pillar
seals and wont work if you have an OEM Header seal (it has the 2 side seals attached to it). I will update this thread if any become available, but hopefully
it might inspire anyone who would like to replicate the idea as it works exceptionally well, think of it this way, its only an Intermediate and a forward seal without the joint. :wink:
Monaco S2 #406
Jamie N
Seal God
Postby Elanlover » Sun 19.05.2019, 16:19
Jamie N wrote: The other thing to note is that these seals are matched to the one piece Header / A pillar
Soooooo........a production run for both then. :poke: :-D
Postby abmunro » Mon 20.05.2019, 00:15
I would definitely be interested, I haven't fitted new hood or new all in one header seal yet
abmunro
Postby lotusrepair » Mon 20.05.2019, 03:06
Sounds like you could offer a complete seal set then???
lotusrepair
Postby Kipperozzy » Sun 02.06.2019, 14:05
Hi Jamie, it was good to meet up with you yesterday and have a look at your new seal design, what a great idea and certainly looks better than the 2 piece intermediate seals. Also the fact that as these get easily removed before putting the hood down eliminates getting the ends damaged like the original design. And seconds to fit back together. 10/10 for this design . :clap:
Also better aerodynamically as mine sometimes whistles when going fast with the hood up, my current solution for that is to go fast with the hood down :-D
Kipperozzy
Postby djwazza68 » Mon 21.10.2019, 23:05
Hi Jamie
I've been reading the seal posts avidly having just bought a tidy but leaky SE. I need to fix a poorly set up hood frame first, but once I have I really need all new seals. I'd buy them, but would prefer to make the new one piece items. How do I start!? :-)
djwazza68
Postby Roger D » Mon 28.10.2019, 13:40
Hi Jamie,
I'm with djwazza68, in that I've just got a nice but leaky SE that needs not only a new hood but sorting the seals seems the way to go.
Are you considering a for a consideration going into a batch run?
Black K Series Elise S2
Claret Excel SA (now sold)
Silk Red Elan SE
Roger D
Postby John Tsakas » Thu 24.06.2021, 17:14
Hi , do you still have these seals for sale?
How much it cost?
Thank you
John Tsakas
Lotus Elan SE British Racing Green 1992
Lotus Elan S2 Pacific blue #125
Lotus Elan SE Monaco white 1993
Lotus Elise S2 Laser blue Touring Pack
Lotus Elan SE Midnight blue 1991
John Tsakas
