Window glide direction
Postby lotusrepair » Thu 24.06.2021, 17:30
I forgot to take note when I pulled the glass out what direction the glides on the front and back were pointing. I put new glides on but do they point towards each other or away on the front and back?
lotusrepair
Re: Window glide direction
Postby petezipp » Thu 24.06.2021, 21:52
Hi, Not quite with you , mean glass felt guide?
they only go one way surely
peter
See that in the sky is it a Tesla No it's a Mitsubishi MU-2 in Lotus ,Black & Gold
petezipp
Postby lotusrepair » Thu 24.06.2021, 22:23
The slider blocks that run in the front and rear rails have mounting holes that make them offset. The mounting hole is not center so when putting them back what direction do they face? Either they point towards each other or away as with the photo. No info in the manual and nothing when searching.
lotusrepair
Postby esprit888 » Fri 25.06.2021, 01:09
It's in the service bulletin manual -V6 (page 28)
esprit888
Postby lotusrepair » Fri 25.06.2021, 02:34
Thanks for the diagram. I was told that the first blocks were as in the diagram with the mounting hole in the center. All the blocks now have the hole offset. Did that tech bulletin get updated?
lotusrepair
Postby esprit888 » Fri 25.06.2021, 18:53
Its not really offset, the sliders only had rollers on one side of the block making the other half redundant. Early cars only had three sliders, orientate the rollers as shown in the bulletin, also more info on page 27 of the bulletin which is in the manuals section at the top of the page.
esprit888
Return to Doors and Windows
