by dapinky » Wed 16.08.2023, 19:36
I know this thread is old, but there are some "recent" bits which I am interested in ascertaining that my information is correct - or if not, definitively establishing that it isn't.... does that make sense?
Anyway, I drained my tranny this afternoon, and the stuff that come out wasn't too grotty, but I have no idea how old it is, so decided that a change makes sense at this point.
Anyway, I fabbed up my version of "the tool" for the 'D' plug, which consisted of about an inch of scaffold pipe with about 8mm cut out of it so I could beat it round to a smaller diameter which just slipped over the plug...... then welded it up and added some weld to the inner edge for a small bit of it, then ground it down to make the 'flat' bit. After a few trial fits, and a bit more grinding I ended up with a nice fit and looked around for something to drive it with. I settled on an old front hub nut as it is the right diameter so was easy to weld onto the end of the tube. I had no idea how tight the bolt was going to be, so it was over-engineered in the welding department!!!!
Anyway, it went on and a selection of extension 'wobble' bars meant I could get a handle on it, and it came undone really easily, so either I was lucky, or my engineering is excellent (I'm tending towards the former).
So, with the whole lot drained I set up a length of pipe from the engine bay (down by the header tank) and into the fill hole, and jammed a funnel in it.
Now, this is where my quandy comes in - I had the car on level ground and added 1.5 L of oil, then did smaller amounts, expecting it to overflow at some point soon......
.... anyway, I have added just over 2L and it ain't dripping out yet - so - did anyone ever establish if the 'filler plug' is actually a filler plug set at the right level, or is it just used at the factory to fill a completely dry unit with a measured quantity for first use (which is why it is an awkward bugger to get out)????
I think I know the answer, and will be removing the speedo drive tomorrow to set it the "proper" way.
If I feel magnanimous, I will then fill the box until it does drip out, then see how much needs draining to get to the right level as per the speedo drive, so we will have an idea of how accurate the 'fill plug' is (or not) and if it is worth using it!
