quality leather and operate smooth with great ergonomics. The not so good news is that they are a bit of mission to adapt them to the Elans mounting points, although once completed they
sit beautifully well and virtually drop straight in, tighten the original bolts and off you go.
The factory brackets on the rear of them need the spot welds drilled out and removed completely from the runners, the front needs the brackets repositioned but with an additional part welded
in place which then takes the mounting bolts. The SRS is also removed completely leaving only the plastic cover which is really only visible with the door open so isn't an issue.
Although they are slightly taller than the originals they don't have any interference with the hood at all, closes fine with plenty of clearance all round, the drivers seat is adjustable for height and at the
lowest setting they actually sit a bit lower than the originals, so a possible benefit for taller owners. They weigh 1.4kg less than the factory S2 seats.
They also have the pull to recline / tilt forward as opposed to the Elans wheel, and the forward / back adjust is a far better and easier bar than the small one on the Elan.
The yellow ones are as close as you'll get to NMY, although difficult to pick up the true shade on camera it's very close, I think they would look really good in a NMY or a BRG, the red ones would go with most other colours.
If anyone is interested in changing out their old collapsed seats I currently have 3 sets of these, although not sure which ones I will keep, so 2 sets are definitely available.
There might also be a pair of immaculate S2 seats in red / black with the red piping, visible in the 3rd picture down. I was swithering whether to keep them for the sake of originality but the reality
is the car already has mods, same as most owners, and combined with the fact that I don't intend selling the S2 and I think the latest seats look / operate fantastically well then may as well
clear some space.
The yellow ones side bolsters are actually dark graphite, looks stunning up close, you can see the difference here against the S2 black bolsters.
I also have these one in black / red and another pair which are all red a bit like the red S2K seats although not quite as bright red as these ones.
