FunElan wrote:You work FAST, or at least that's what your post makes it seem like!
FunElan wrote:Curious what you think of the performance after the chip. I still don't know if mine has the chip, but boosting up to .9 is fun
FunElan wrote:Any special tricks you used to remove the driveshafts? I'm about to do that job.
378S2 wrote: I recently bought the Impulse sump gasket from RA for $3, plus about a thousand dollars postage. I bought it because it looks less messy and more likely to go on correctly than I would be able to manage with silicon.
378S2 wrote:I have almost the exact same amount of oil in my air intake...
378S2 wrote:Will you DIY the seals or pay a professional to do it?
TorqueHorse wrote:I'm really hoping it isn't the output shaft seal area thingie causing the leak because I am not taking that tranny out again unless I have to.
Tuga2112 wrote:now that you publicly said you done it. your the expert at steering racks...
dont be surprised if your getting PMs from me sometime in the future when i finally get mine out and decide to DIY it instead of just handing over to someone else.
Excellent write up TorqueHorse
that's tremendous. Thank you
TorqueHorse wrote:Ahhh, sorry, it's been a minute since the last update.
Progress being made, slowly but surely on the rolling restoration. Problem now is deciding between fun driving time, or working on the car time...so working on the car gets the backseat![]()
I did just hit a bit of a rough patch this past week with what seemed like dead cylinders 1 & 3. Wanted to go ahead and post this before I forgot and moved on to other stuff. So, since it was 1&3 I was thinking it was the injector circuit, or injector related. Especially since when I took the spark plug leads off the plugs I could hear clicking when I held it to the valve cover...But after a lot of messing around with the injectors, it did end up being the spark plug cables, and the points on the coils.
It ends up that when I took it in to a mechanic to do a pressure/combustion gas test, they just let the coolant bubble everywhere and it soaked all the electrics beneath. I can't say for sure it wasn't from another leaking event in that coolant expansion tank, but the timing was suspicious. Anyways, with a different set of plug wires and cleaning up the points on these coils, the spark is now strong enough to get the plugs working again. Back to normal now, but quite a circuitous path.
