by dapinky » Fri 16.02.2024, 11:24
Edit:- Was writing this at the same time Joao was posting his reply, so much is duplicated!
Jon,
Fixing this 'issue' is something which should take about half an hour, but will probably end up as a weekend's worth of work! I say this as a man who has removed and replaced the whole lot on every Elan I've owned.
Basically, the front bumper needs to be adjusted - and this is a "simple" case of releasing some bolts, moving it, and tightening the bolts - except they are 30+ years old, likely to be corroded, and need getting at to start with.
You may get away with 'just' adjusting the small strap-link behind the wheelarch liner (it is a strap of steel bent in a dog-leg shape, attached to the bumper, and attached to the clamshell. It is attached by way of a steel threaded bar bonded to the clamshell, and a couple of 10mm nuts to adjust it's relative height..... They are often easy to get at, once you have removed the wheelarch liner (or peeled back the front half of it), but if the threads are rusted, it is possible to damage the thing with force. So it is important to support the threaded bar when undoing the nuts.
Obviously, shortening the fixing will lift the bumper up a bit towards the clamshell.
However, there are also bolts through the end of the bumper which need to be released first, and then locked into place when the adjustment is done - these go into the fibreglass moulding for the oil cooler and intercooler housings at each end of the bumper.
To do the job fully, you will also need to undo (but not remove) the 4 x M8 fittings behind the centre of the bumper, which are the main mounting points for it - this will allow any movement of the fibreglass bumper to be unstressed as opposed to being left a bit 'twisted' but the earlier adjustment. These 4 nuts/bolts are easy to undo if they are not corroded, but a bit of a bugger if they are!
Page 10.23A in the Parts Manual shows the whole thing, but doesn't really show how awkward some of the bits are to get to.
Basically, the procedure is to undo the 4 central nuts, being careful not to drop any of the adjustment shims (as the position of those appears to be fine as-is), loosen the end of bumper to quarter panel nuts/bolts, remove the wheelarch liner (enough to gain sufficient access to the fixings). Adjust the fixing strap relative length to set the gap as required, tighten up the fixing bolts and refit the arch liner.
As siad, it could be half an hour, or it could be longer - it's all down to ease of removal of old nuts!!!
