alan e wrote:Dave is it worth disconnecting the LEDs and then retest it to see if the fault is still there if it is its not the LEDs.
I thought those LED's looked rather fetching Dave, I hope there not the cause of the problem, as I fancy a set
dapinky wrote:alan e wrote:Dave is it worth disconnecting the LEDs and then retest it to see if the fault is still there if it is its not the LEDs.
It is certainly the LED Headlamp circuit that does it - I can drive on side/tail lamps for a long time with no CEL, but 2 minutes after putting the headlamps on, it illuminates. It is something on that switched circuit that it doesn't like - but I can't think what or why.
dapinky wrote:Thanks Tony, I never considered RF interference, but it makes sense..... would shielding work?
dapinky wrote:3) The one which has me scratching my head is a bit off an oddity that I haven't heard of before, so I am hopeful that an electrical guru will know the answer..... as said, the weather was 'mixed' on the way home, and I haven't ever driven it in the dark...... so on occasion I had to put the headlights on. Then, after about 2 minutes of dipped beam use, the CEL came on but the gauges all looked fine and there was no noticeable change in driving conditions. When I turned off the lights, the CEL went out after 3 or 4 seconds. It did the same the next time I put the lights on.....
...... so, why? I don't know if it is because of the LED units I have fitted, or if it happened before with the OE lights as I never drove it under those conditions, so can offer no other information.
