Replaced all the bushings, bearings, and ball joints in the front suspension. (Need come back and add photos)
Replaced the original rear dampers(one finally started leaking) with some GAZ units. Have some for the front too, just haven't gotten there yet. I've got new bearings in the rear on both sides now. Got one of my rear rotors skimmed because it had a high spot (thank you o'reilly). But my brake sliders keep binding and I'm really tired of taking the brakes off to try and get them moving again. Both sides are acting up.
Had to respool one of the window regulators. Took both sides out, cleaned all the tracks, replaced the plastic bits, changed out all the rusted fasteners with SS, installed new guide sweep "caterpillars" at the top inner edges of the windows. Installed the windows. Ready to put on the new window seals at the top outer edges. Worst part was one of the bobbins had seized on there and had to drill it out. Worried about breaking the plastic or the glass, or the aluminum holder, but got it all out. Replaced those bolts with SS. But now for the first time since I bought the car, the windows work
Replaced the hood, and cleaned up, treated, and painted the rusting frame. Put new stretchy straps in on top too, but they've already gone limp in less than a year. Now I've been continuing to get the fabric to lay the way I want around the back edge. Bloody hard to get it down around the bottom, right at the B post. I had gotten it close, but it still needed about 3/4" more so I took it to a Top Shop, and they didn't really want to touch it either. They thought I had done well enough with the rest of it, and I just needed to "pull more" to get it done. So now I'm back to pulling for dear life to get it around the bottom. I took out the "mucket seal" at the deck lid at B-post and that gave me more room to work. Got one side looking right now. Need to have a span of free time (and weather) to get the other side done. Started putting in new falling b-post seal in the aluminum channel. That was a 2 day nightmare getting one seal in there; can't wait to do the other side
Had a hail storm that made the original windshield (which was already cracked) completely shattered, so I finally got around to installing my replacement windshield...and then managed to break it while installing it
Finally got her painted though, so that has been a highlight.
Coming up:
- Fix the back brakes (again, again).
Get the new, new windshield installed.
Finish fitting and trimming the convertible top fabric and new seals.
Ceramic coating the plastic trim and reinstalling it all and making the trunk(boot) water tight (lots of leaks around the lights and license plate now).
Taking out the engine again, again and cleaning up/replacing the cylinders and pistons again. I have a lot of blow-by and still burning oil and my fuel efficiency is only around 21.5mpg (chipped), and it could be happier at idle at cold start, so I think I have some work to get it really humming.
Get the new front dampers in.
Change out the AC compressor, drier, and condenser.
Put in the new seats, and retrim the interior leather.
Try and fix the original head-unit (shorts out after 20 seconds of playing).
Work on cleaning up the wheels.
Cruise around and have fun
Hope to be back soon with more updates.
You can see the enlarged holes on the right side.
