by Sy V » Tue 30.12.2003, 07:02
Have I found something here? Stumbled across this late yesterday evening:<br><br>IMPULSE TURBO <br>1588cc 4XE1WT 91-93 <br>Head Gasket CH5566 £54.51<br>Head Set HK1565 £114.72<br>Conversion Set CK0347 £19.49<br>Valve Cover Gasket RC1374 £12.17<br>Valve Stem Oil Seals VK5367 £22.69<br>Hydraulic Lifters HL6370 (x16) £36.48<br>In. Manifold Gasket MG6595 £3.83<br>In. Manifold Gasket AG9681 £3.73<br>Ex. Manifold Gasket MG6592 £7.33<br>Sump Gasket OP4371 £5.31 <br>Front Crank Oil Seal OS5392 £3.38<br>Rear Crank Oil Seal OS3380 £4.96<br>Camshaft Oil Seal OS6381 (x2) £1.05<br><br><br>There appear to be other parts like CV joints too...<br>
- LEC Godfather
by rob » Tue 30.12.2003, 10:57
Sy, where did you find these ???<br><br>I could be interested in a set of hydrolic lifters, bargain 16 for £36.
rob
by Sy V » Tue 30.12.2003, 11:35
Rob<br><br>http://www.webparts.co.uk/<br><br>
Under BG Automotive then
Gaskets & Oil Seals then
Search by Vehicle then
Isuzu then
Impulse.<br><br>I think
<br><br>I also think it might be 16 x £36 mate.
- LEC Godfather
by rob » Tue 30.12.2003, 12:46
On second thoughts, my lifters are fine ::)
rob
by DeeAitch » Sat 03.01.2004, 18:30
Just noticed the lifters are listed as being common to several Suzuki engines (Swift, Vitara etc)<br>Strange ???<br> :-/Can anyone confirm/own up to having one?
DeeAitch
by Jeffbro » Mon 26.09.2005, 19:09
As I am currently undertaking a head gasket change, thought i'd chance it with the Isuzu Impulse parts mentioned by Sy. I can confirm that the camshaft oil seals and the valve seals are a perfect fit! (saving almost £100 when compared to Lotus/specialist prices
). I would wager that the majority of the other parts will fit also!
Jeffbro
