Locking Wheel Nuts
Locking Wheel Nuts
Postby scubaruss » Fri 26.08.2005, 13:10
Can anybody tell me if I need to buy a specific set of Lotus locking wheel nuts for my 1990 SE Turbo or can I simply go to say Halfords & get a set?
scubaruss
Postby Rambo » Fri 26.08.2005, 13:16
Halfrauds stock McGard locking wheel nuts for the Elan (M12 x 1.5 27179 SU) and they will fleece you £29.99 for the set.
Mark
Postby scubaruss » Fri 26.08.2005, 13:49
Rambo wrote:Halfrauds stock McGard locking wheel nuts for the Elan (M12 x 1.5 27179 SU) and they will fleece you £29.99 for the set.
Mark
Thanks Mark....an informative response from a bitter man :wink: I shall make my way to Halfords & take it like a man :!:
scubaruss
Postby Fubar1764 » Fri 26.08.2005, 14:34
Anyone know a source here in the Colonies?
-Your "Jack" of all trades
Fubar1764
Postby Doug » Fri 26.08.2005, 17:18
Fubar1764 wrote:Anyone know a source here in the Colonies?
since the Elan OE uses wheel 'bolts' I doubt you will find them without a specialty shop, Jack. If you convert to wheel studs (as I and others have done for aftermarket wheels) then you can find locking wheel 'nuts' at the local auto parts place likely . . .
Postby Matt RI » Mon 29.08.2005, 16:24
A long while back, Nitro had posted info regarding an ebay item that has worked for me.
TunerLugs: http://cgi.ebay.com/ebaymotors/TunerLug ... enameZWD1V
I am not sure if this is the EXACT bolt kit I purchased or not, though. I have to check the cone angle. The ones that I purchased were M12, 1.5, and IIRC 30mm (a little longer than standard I think- but work fine for me).
I would check the length, angle, and thread pitch of the standard bolts against the offerings if you are interested in any of these products- as they have a lot of options. Could easily go the stud/locking wheel nut option as Doug mentioned also- as now I need to get 12 shiny wheel bolts to match my shiny locking ones!
Matt RI
Return to Wheels and Tyres
