Hood Options - LEC Discount
Re: Hood Options - LEC Discount
Postby Adam » Wed 23.03.2005, 13:33
All the seals around the hood including rear seal are provided.
Adam
Postby Sy V » Wed 23.03.2005, 16:00
I stand corrected.<br><br>Good price that then!
LEC Godfather
Postby Doug » Sat 26.03.2005, 00:35
that is a freaking deal then!<br><br>this is the one you have Sy, right.<br><br>Too bad I didn't get to see and appreciate what a green top looks like (in hard or soft form) in person last week.  I was planning to decide if I wanted a green top or not   :-/<br><br>Actually I was impressed how few non-black tops there were.  Remember only about 2 blue ones on azure blue S2's<br><br>Does this kit come with new cables I hope, as well??  How about the elastic ties between the bows?<br><br> 8)
Postby Sy V » Sat 26.03.2005, 07:42
No Doug<br><br>I got my new seals from Dean, but my hood was supplied and fitted by Autohoods.<br><br>http://www.autohoods.co.uk/list_lotus.htm<br><br>
LEC Godfather
Postby Sy V » Sat 26.03.2005, 07:43
Trim Tech will replace webbing and tension cables on an "as needed" basis, but they're extra.
LEC Godfather
Postby nchase » Thu 07.04.2005, 08:08
Quote from John at TT today.....<br><br>Morning Nicholas, all parts are available for lotus retriming operation, however due to production requirement for 250 complete Lotus Hoods currently taking place, we will not be in a position to undertake any individual retrims till beginning of June 05.  <br>
nchase
Postby Adam » Thu 07.04.2005, 10:08
the webbing and tension wires were also included in the price.
Adam
Postby Stef » Thu 07.04.2005, 12:29
No Blipi!  I won't get you another treat!... yet ::)
Men are like a fine wine.
Stef
TVR/PistonHeads Ambassador
Postby Paul.P » Thu 07.04.2005, 13:18
If she's ought like the rest of you women, she will get her own way ! ;)
Postby Sy V » Wed 13.07.2005, 11:20
http://www.trim-technology.com/
Our hoods are now in stock.
Following the link will get you to the products which are available in a choice of colours with seals webbing etc.
I can confirm that these hoods are the S2 version (slightly wider over the doors and with the extended S2 shape rain flange to the rear of the door windows).
They will fit SEs with the addition of a header rail extension that TT can fit, no problem.
IMHO this represent the very best value for money available to us at the moment.
LEC Godfather
Trim Tech - Hood
Postby desmondsee » Tue 19.07.2005, 03:29
Hello guys, just to let all know that i have placed an order for delivery of the hood and full set of seals etc. Will provide feedback after fitting. So far, the service and response has been excellent and lightning fast, which speaks alot on their "keeness" to be a responsible and responsive supplier :)
desmondsee
Postby nchase » Wed 20.07.2005, 20:40
Good hood, good service, and great hospiltailty whilst I was there. John is an excellent bloke and very proud of the business.
Do check the fitting/gluing of the seals, one of mine was not glued very well, not sure that the glue that they used was the correct one ' according to local dealer'..... that said TrimTech are replacing it FOC for my local dealer to fit.
Frame and roof all fine. Thoroughly recommended.
nchase
Postby desmondsee » Wed 17.08.2005, 12:07
just want to say that the hood and seals are fitted. excellent fit. also it comes with the sides bracket extensions (s2) so that the elan (s1) will have less of a wet knee syndrome.
i need to replace the seals on the left and right of the windscreen and also real seal (gasket moreso) around the chassis flap where one opens to fold and keep the hood.
anyone done this or know where to get this?
at last...
desmondsee
New Hood Fitted By Trim Tech
Postby jc_martin » Tue 13.09.2005, 09:13
Ordered a hood/seals kit from Trim Tech earlier this year, had it fitted locally as TT were busy with a block order and I couldn't be bothered to drive from Sussex to Coventry. Local fitter assured me he'd fitted plenty of M100 hoods before, it was him that advised me to make sure I had a new header seal "as they usually break when you remove them".
Hood fit was okay but this bunch of muppets totally messed up the seals, header seal was up and down like a fiddlers elbow, window seals were fitted to wrong sides of the car, everything was glued and they'd even managed to get that on the seats and bodywork. Returned the car to them and they did a slightly better job but the header seal was damaged due to removal and refitting.
After a couple of months I could no longer live with it and decided to see if Trim Tech could sort it out for me. Peter Randle was most helpful and even arranged to meet me at the factory so that I could drop off/pickup on consecutive weekends rather than take a day off work.
Unfortunately the hood and seals were write-off, Trim Tech fitted a whole new set including a reconditioned frame. Picked it up at the weekend and it looks superb, the fit is so good that the seals are hardly visible at all, drove back in the rain - no leaks.
If anyone is thinking of using a local fitter to fit one of these hood/seal kits I'd advise you think long and hard about it. You're trusting them with £600+ worth of hood/seals and as you've supplied it you've got very little comeback if they mess up.
Trim Tech offer great hospitality and service, they fit these things all the time, know what they are doing and are proud of their work. You'd be a fool (like me!) to risk your money elsewhere.
jc_martin
Postby Sy V » Tue 13.09.2005, 10:02
Looks like TT are serving us exceptionally well.
Thanks Dean and the gang...keep it up!
LEC Godfather
Postby JoPaS » Fri 16.09.2005, 00:18
And what about us? non UK's? I'm from Portugal, and my elan leaks like if there is no soft top.. lol, the right window has almost 1cm of gap betwen the window and the ruber.. when i wash the car i can't throw watter directly cause it enters inside the car... all over the seat... is it a seal problem? or is it the top?
JoPaS
Postby Sy V » Fri 16.09.2005, 06:01
I don't know for sure but I would guess that your window needs adjusting.
LEC Godfather
Postby Sy V » Tue 20.09.2005, 11:29
Got an e-mail from Dean Holt last night...after this morning's negotiations Trim Technology are willing to offer us the deals outlined below:
These are all on a part-ex of your frame basis:
Refurbed frame (fitted to your car) with new canopy, seals, webbing etc £700 +VAT - 10% LEC discount. You will pay £740.25
Brand new frame (pick-up/delivered) with new canopy, seals, webbing etc £1125 +VAT - 12.5% LEC discount. You will pay £1156.64
Brand new frame (fitted to your car) with new canopy, seals, webbing etc £1400 +VAT - 15% LEC discount. You will pay £1398.25
Canopies are available in Black, Blue, Red & Green.
Their canopy & seals only service, alluded to earlier, remains extant.
Big thanks to all at TT for their continued support.
LEC Godfather
Postby theelanman » Tue 20.09.2005, 11:59
Sy
was there an option for refurbed frame fitted?.....
just wondering about driving down unbolting the old one and swaping it there and then and then fitting the new/refurb one for the trip home....
or is the refurb option a refurb of yours (ie it takes them a week to strip ,fit, post etc etc)
cheers
G
Postby Sy V » Tue 20.09.2005, 12:35
"was there an option for refurbed frame fitted?....." No, there is no such option.
They refurb one of the last frames in and you get it fitted to your car.
LEC Godfather
