Gaskets and Seals?
Gaskets and Seals?
Postby Sy V » Tue 30.12.2003, 07:02
Have I found something here?  Stumbled across this late yesterday evening:<br><br>IMPULSE TURBO <br>1588cc   4XE1WT 91-93 <br>Head Gasket    CH5566  £54.51<br>Head Set    HK1565  £114.72<br>Conversion Set    CK0347  £19.49<br>Valve Cover Gasket    RC1374  £12.17<br>Valve Stem Oil Seals    VK5367  £22.69<br>Hydraulic Lifters    HL6370 (x16) £36.48<br>In. Manifold Gasket    MG6595  £3.83<br>In. Manifold Gasket    AG9681  £3.73<br>Ex. Manifold Gasket    MG6592  £7.33<br>Sump Gasket    OP4371  £5.31 <br>Front Crank Oil Seal    OS5392  £3.38<br>Rear Crank Oil Seal    OS3380  £4.96<br>Camshaft Oil Seal    OS6381 (x2) £1.05<br><br><br>There appear to be other parts like CV joints too...<br>
LEC Godfather
Re: Gaskets and Seals?
Postby rob » Tue 30.12.2003, 10:57
Sy, where did you find these  ???<br><br>I could be interested in a set of hydrolic lifters, bargain 16 for £36.
rob
Postby Sy V » Tue 30.12.2003, 11:35
Rob<br><br>http://www.webparts.co.uk/<br><br>Under BG Automotive then Gaskets & Oil Seals then Search by Vehicle then Isuzu   then Impulse.<br><br>I think ;-)<br><br>I also think it might be 16 x £36 mate.
LEC Godfather
Postby rob » Tue 30.12.2003, 12:46
On second thoughts, my lifters are fine  ::)
rob
Postby DeeAitch » Sat 03.01.2004, 18:30
Just noticed the lifters are listed as being common to several Suzuki engines (Swift, Vitara etc)<br>Strange ???<br> :-/Can anyone confirm/own up to having one?
DeeAitch
cam oil seals and valve seals fit!
Postby Jeffbro » Mon 26.09.2005, 19:09
As I am currently undertaking a head gasket change, thought i'd chance it with the Isuzu Impulse parts mentioned by Sy. I can confirm that the camshaft oil seals and the valve seals are a perfect fit! (saving almost £100 when compared to Lotus/specialist prices :lol: ). I would wager that the majority of the other parts will fit also!
Jeffbro
Postby Sy V » Tue 27.09.2005, 03:55
Result... 8)
LEC Godfather
