Dico's project
Postby Doug » Mon 13.03.2006, 23:26
no knowledge on the socket front.
chant along with me:
"Niter's kit"
"Niter's kit"
"Niter's kit"
just think of the sad look on Monty's face :( when you install the NOS and go for a drive with the Pinky-mobile in your rear-view mirror :twisted:[/b]
Postby Paul.P » Mon 13.03.2006, 23:32
Doug wrote:just think of the sad look on Monty's face :( when you install the NOS and go for a drive with the Pinky-mobile in your rear-view mirror :twisted:[/b]
Youv'e got a twisted mind Dougie, sure you ain't on commision with this NOS ?
Postby Monty » Mon 13.03.2006, 23:35
He`ll only end up in the field with the sheep if he tries using NOS on those country lanes :-D
Anyways Doug he`s got to get the Dam thing back on the road :lol:
Hey Paul those sockets do look like the correct ones :roll:
Postby Candles » Tue 14.03.2006, 09:28
The hexagonal socket they refer to is just a posh name for an allen key hole in the middle of the tensioner. It allows you to put pressure on the belt to get more tension than the spring provides whilst tightening the nut that clamps it. All you need is an allen key (6mm iirc).
Candles.
Candles
Postby Doc Fizzix » Wed 15.03.2006, 02:36
Doug wrote:no knowledge on the socket front.
"Niter's kit"
"Niter's kit"
"Niter's kit"
YES! :D
Say it with Doug
"Niter's kit"
"Niter's kit"
"Niter's kit"
Doc Fizzix
Postby Dico » Wed 15.03.2006, 21:50
Cheers Candles :)
Good old lotus with their clear descriptions :?
Tried selling the 4x4 yesterday to pay for the NOS, but it did'nt happen :(
Postby muley » Thu 16.03.2006, 12:08
Youv'e got a twisted mind Dougie, sure you ain't on commision with sniffing this NOS ?
Postby Dico » Sun 19.03.2006, 21:52
Back from the galvanizers.
Bling it on bro!
Picture 037 (Small).jpg (76.5 KiB) Viewed 172679 times
Postby Monty » Sun 19.03.2006, 22:09
Look better in the photo`s :roll:
Postby Dico » Sun 19.03.2006, 22:24
Managed to undo the idler/tensioner (splined) bolts today. The idler bolt was unbelievably tight!
New idler and tensioner ordered - £$£$£$£$ !!! :shock:
Note the engine oil, which leaked out of the flywheel bolt holes after they had been removed.
After 7 years of use (20,000 miles) the cambelt was still in very good condition. Being changed though.
Picture 045 (Small).jpg (56.17 KiB) Viewed 172653 times
Postby Doug » Mon 20.03.2006, 08:13
Dico wrote:Back from the galvanizers.
looks worlds better :smt023
Postby Rambo » Mon 20.03.2006, 14:18
Game-On of the North !! Did you galvanise your beer cans as well ?? LOL
Mark
Postby Dico » Mon 27.03.2006, 13:50
Mark, as you well know, i dont touch alcohol :smt030
Can someone please advise -
How on earth do you install the Alan Betts nylon bushes into the gear leaver mount? (the ones that replace the rubber bushes) I would post a pic but the digital camera is in mrs Dico's glovebox :?
I dont see how that even if you did manage to remove the original rubber ones, (which appear to be in one piece) how you would fit the nylon ones in their place?
I'm obviously missing something here.... Help!
edit-
erm... sussed it! pretty obvious really :oops:
The metal insert in the original rubber bush can be removed enabling you to 'squish' the rubber bush out.
The new one isnt one piece as i assumed, but splits into two, making the job straightforward.
Alls clear after a sausage roll and a cup of tea :)
A picture would make all this a lot more clearer for anyone who has'nt yet done it.
One will follow shortly.
The reason for changing these is that the nylon bushes apparently give a more positive feel......... i'll let you know :)
Bottom right = new nylon bushes
Bottom left = old rubber bush with metal insert removed
IMG_1230 (Small).JPG (41.05 KiB) Viewed 172503 times
Postby Dico » Fri 31.03.2006, 20:57
Tomorrow i am attatching the flywheel, but at this point have to admit to never having used a torque wrench.
The service notes are telling me to tighten the flywheel bolts in two stages -
1st step - 30nm (22 1b.ft) this i can just about understand
2nd step - 45 degrees - 60 degrees this i dont understand :?
I can only asume that the 2nd and final step i have to turn the wrench an extra 1/8th of a turn or so. Seems a bit aproximate to me, surely this cant be the case on such an accurate piece of equipment ? I would have thought an extra couple of NM's would be more likely?
Can anyone enlighten me please?
Postby GeoffSmith » Fri 31.03.2006, 22:56
I'm sure that's right Dico. Did a Metro head (for my lad to learn to drive on last year) and that was torqued plus two extra ¼ turns all round - the wrench went off scale and it made some worrying noises towards the end.
Good luck with the project - let's see more photos.
Postby Dico » Sat 01.04.2006, 21:55
Cheers Geoff, i ended up tightening it up an aditional 1/8th of a turn.
Spoke to my brother in law who works on aircraft bodies, he could'nt understand the second step that lotus sugested :?
Anyway, progress was slower than expected today, i dont know why i was suprised as thats how this project has been all along :)
Cambelt replaced along with tensioner and idler bearings. Lightened flywheel fitted. clutch/pressure plate fitted. (almost, awaiting Montys alignment tool prior to tightening)
Easy job tomorrow, fit the stiffy and (maybe) fit the AB gear cables to the gear stick end. Its almost becoming enjoyable :D
Did'nt take any photos which is a real shame, promise to make more of an effort tomorrow.
Postby Dico » Sun 02.04.2006, 16:52
The turbo wastegate has been ported (drilled) from 16mm to 20mm to prevent boost creep, which 'may' happen after fitting a larger bore exhaust or increasing boost.
The only real way to do this is to remove the turbo from the engine.
(my engine was removed)
Ported wastegate
IMG_1189 (Small).JPG (35.02 KiB) Viewed 172414 times
Postby Dico » Sun 02.04.2006, 16:55
Stevos aftermarket downpipe -
Stiffy prior to being ceramic coated
IMG_1184 (Small).JPG (27.25 KiB) Viewed 172413 times
Postby Dico » Sun 02.04.2006, 16:59
The original studs have been replaced with stainless bolts.
Note that the bottom left one is shorter than the other 3, as this is the only one that does not protrude through the turbo casing.
Stainless bolts-test fit
IMG_1232 (Small).JPG (60.28 KiB) Viewed 172412 times
Postby Dico » Sun 02.04.2006, 17:03
After initial fitment i found out that the stiffies bracket which secures it to the engine block had too small a diameter hole. Removal was the only way i could drill the holes larger :?
Hole enlargement
IMG_1234 (Small).JPG (63.68 KiB) Viewed 172411 times
