My AB cables arrived on Monday, and it's true, they make a
massive difference!
Due to a delay in manufacture, AB also sent me 4 of the delrin parts to replace the rubber bushes between the base unit and the chassis. Because of these removing further play, the definition of the H pattern is even more improved. I would highly recommend getting a set for the improved feel offered. Alternatively if you can't wait, and if you can obtain some plastic washers, then it's quite feasible to make your own. Now that I've removed the rubber bushes and alloy spacer sleeves, I am quite happy to share their dimensions upon request.
I have also been fortunate in that the previous owner invested in a short throw gear selector mechanism before they were discontinued by isuzuperformance.com.
So now I've got a gear selector mech that feels absolutely perfect (or at least it
will when the left/right movement has loosened up a bit!) - minimal movement and dead precise. Groovy.
The installation also gave me chance to study the short throw mechanism compared to the standard one, and there is great news for everyone here: the only difference is the bellcrank arms, as you can see from the pic below. Standard mech is on the left, and short throw mech on the right.
The standard mech's arms are 70mm and 50mm between centres, while the short throw mech's are 35mm and 25mm. So no surprise - the gear lever movement is also halved.
The upper arm is made out of a C shaped piece, and because it's shorter, the pivot pin has to be mounted on the upper face.
This means that the cable ends need to be further apart, so a new abutment bracket is needed (which is different again if you fit AB cables).
Again, I took measurements of the brackets, and can provide these if required.
Upshot is, if you can get the arms cut and welded to the specifications above, and a new abutment bracket made like the one in the bottom right of the pic, you've got a short-throw gear lever.
