Click on the screen below
Monty wrote:... Another weird thing is i'm only getting 1 BHP higher than Dave's (Peco) SE and his doesn't have a chip just standard besides the exhaustso doesn't say to much about the chip really
unless this was down to the crapy dump valve as this was passing even on low revs.
Monty wrote:Dam i didn't even think about running the ElanScan ... Dave over lapped his run over mine and there wasn't much in it and most of the graph showed the runs were very similar no reall big difference
Nige wrote:If you plot power or torque against RPM (which is what Dynos produce) they will look simiar. However, if you wind time into the equation you should get a clearer view.
Monty wrote:Yeah, have to agree. If u'r going to port the wastegate then it's worth fitting the stiffy. Another weird thing is i'm only getting 1 BHP higher than Dave's (Peco) SE and his doesn't have a chip just standard besides the exhaustso doesn't say to much about the chip really
Avonvilla wrote:Monty wrote:Yeah, have to agree. If u'r going to port the wastegate then it's worth fitting the stiffy. Another weird thing is i'm only getting 1 BHP higher than Dave's (Peco) SE and his doesn't have a chip just standard besides the exhaustso doesn't say to much about the chip really
Think your comparing Dave's flywheel figure with your wheels figure ? His ebay ad states 175bhp up from 152bhp standard which are flywheel figures surely.
Monty wrote:Avonvilla wrote:Monty wrote:Yeah, have to agree. If u'r going to port the wastegate then it's worth fitting the stiffy. Another weird thing is i'm only getting 1 BHP higher than Dave's (Peco) SE and his doesn't have a chip just standard besides the exhaustso doesn't say to much about the chip really
No thats at the wheel mate
Monty wrote:Yep i'm sure, he overlayed his results over mine and he only does it at the wheels as it's more accurate, he can calculate at fly. Not sure on the standard bhp that doesn't seem right there seems to be 30 bhp lose at the fly which would make standard about 135 at the wheels
Monty wrote:I've not seen the quote on the ebay listing, but don't think that is Dave quoting those figures, think that was PNM engineering selling them on ebayU don't just get 10 bhp extra with an 2 1/4 exhaust it's more like 40 bhp. So thats just a mistake and should say at the wheel. Peco's rolling road only measures at the wheels.
Monty wrote:Your not listening those readings are at the wheels, but i think they've quoting the wrong stock readings. Says nothing about the them being at the fly!
These are on my latest ES run. Peco system, stiffy, Everest chip and Dump Valve removed.
Edit, having trouble resizing these graphs
