Not a cry for help but a solution - locked keys in boot
Postby Russc » Mon 10.07.2006, 12:00
Hi all,
I did a very clever thing this weekend and managed to lock my keys in the boot, yes yes you can stop laughing now :-D
Was told that the only way i could effect entry is by either breaking the rear light or smashing the lock. Obviously didn`t want to do either of these.
There is another way of gaining entry that doesn`t cause any damage to the car.
Obviously i`m not going to post the details here as anyone can read it. However should you ever need the details please PM me and i`ll let you know.
Please be aware, i will not release these details unless you are 1. a member 2. been here a while or can be vouched for by another member.
Russc
Postby delta » Mon 10.07.2006, 12:59
Had a faliur on my lock just last week, but I found a way, where the boot can be opend almost without any damage from the softtop compartment. So no panic.!.
1. Loosen the carpet on the area into the boot.
2. Drill 2 holes 5 cm offside center (to clear the bootlight), One to tool access and one to see through. Bend the boot carpet down for access.
3. Using 2 extensionsrods + 13 mm top, and undo the bolt holding the the lock bracket, and the boot will open.
4. Glue back the carpet, and all signs gone.!.
Pic's incluted.
Delta.
delta
Postby Russc » Mon 10.07.2006, 14:15
Blimey, that`s a lot of hassle.
The way i know takes 10 minutes at most and involves no need to have access to inside the car, or damages the car in any way. Hence why i`m not posting the details up :)
That and you can fir the lock back and carry on as normal. I imagine it would also work on lock failure.
Russc
Postby delta » Mon 10.07.2006, 14:52
Bugger.!.
Send me a PM with that solution, please.
Delta.
delta
Postby Gary » Mon 10.07.2006, 15:15
Russ,
Please can you PM me the solution
Ta
Postby Russc » Mon 10.07.2006, 15:37
Actually the piccies are a good idea. I`ll take some and then put it all together in a guide.
I`ll do that in the next couple of days :)
Russc
Postby TheBard » Mon 10.07.2006, 17:26
Hey Russ,
When you have the guide PM it this way too.
Ian
TheBard
Postby Paul.P » Mon 10.07.2006, 20:42
Gary wrote:Russ,
Ta
AH !, you might be useful for something yet mate ? :lol:
Postby timmo » Mon 10.07.2006, 21:01
PM me as well please Russ, the way things are for me currently , its bound to happen.
Ta
timmo
Postby GeoffSmith » Mon 10.07.2006, 21:29
Me too please Russ - you know it's going to happen don't you.
Geoff
PS there was a posting some months ago about this subject but it looks likes it's been (wisely) removed. I'll PM you what I remember of it.
Postby discovery » Tue 11.07.2006, 08:12
Please pm me with the solution , cheers
discovery
Postby a5gcd » Tue 11.07.2006, 11:45
Please pm me with the solution "just in case",
cheers Geoff
a5gcd
Postby Rogerf » Tue 11.07.2006, 21:58
Please pm me 'just in case'
Roger
Rogerf
Postby jimp357 » Tue 11.07.2006, 23:07
VORSICHT! Die Nordschleife ist gefährlich.
jimp357
Postby malbon » Tue 11.07.2006, 23:38
pm por favor :-D
malbon
Postby paza1 » Wed 12.07.2006, 00:13
Me to please.
Mark
Silver 1992 SE Turbo.
paza1
Postby Doug » Wed 12.07.2006, 00:16
me too
curiousity has got me gripped :shock:
Postby Enright » Wed 12.07.2006, 00:51
Having come very close to doing the same recently, and just in case I'm successful next time, can you PM me the solution too please?
Not a cry for help-but a solution
Postby algirdas » Wed 12.07.2006, 03:47
Dear All:
Ok, I'll bite. Would someone be so kind as to PM me the solution as well. The curiosity is starting to make me just a little bit crazy.
Sincerely,
Algirdas
Noli illegitemi carborundum.
algirdas
Postby Rambo » Wed 12.07.2006, 07:57
Having inadvertently locked my keys in the boot/trunk twice I have become well acquainted with the removal of the lock and replacement thereof. I too have a much easier solution now but I would be interested to hear if Russ's is simpler ?
Mark
PS Who on earth did Lotus not couple the boot/trunk up to the central locking when they initially designed it ? Yet another of Hethel's idiosyncrasies !!
