Drivetrain problems
by Doc Fizzix » Mon 04.09.2006, 01:58
I know we have talked about this many times but it looks like some of the threads have been dropping off and now I wanted to read through some of the old informaiton but it is gone
Well, here it goes again. What is every one using for trany oil?
Is Moble One 10/30 motor oil ok?
Doc Fizzix
by Doug » Mon 04.09.2006, 07:05
I wouldn't use it -- go with the RedLine -- esp if you have the LSD in there!
- LEC Founder
by Candles » Mon 04.09.2006, 08:53
Redline MTL for me as well. It does make it smoother, really!
I've just developed a speedy-filler as well: A bolt, drilled hollow with the head sawn off and a plastic tube attached. This is screwed into a redundant bolt-hole in the top of the gearbox. I simply drain (I flushed with some spare oil as well) then pour 1.8L of (warm) MTL into a funnel attached to the tube. When finished, I remove the funnel, insert a bung and cable tie it next to the airbox.
I reckon I could change the oil in about 5 mins! Brilliant!
Candles.
Candles
by Doc Fizzix » Mon 04.09.2006, 16:50
Doug wrote:I wouldn't use it -- go with the RedLine -- esp if you have the LSD in there!
Good point! Forgot about the LSD I just put in
Doc Fizzix
by Doug » Mon 04.09.2006, 18:29
Candles wrote:I reckon I could change the oil in about 5 mins! Brilliant!
can't wait to see the video!
- LEC Founder
by Candles » Mon 04.09.2006, 23:07
Sadly I've done it now and didn't take any pictures so any future pics would be a faked re-enactment which you lot just wouldn't be satisfied with....
Next oil change I guess!
Candles.
Candles
by Doc Fizzix » Thu 21.09.2006, 21:29
How about just using a hand pump?
Doc Fizzix
by Enright » Thu 21.09.2006, 22:05
I just changed mine, using the recommended Castrol TAF-X.
It took a bit of getting hold of, and it wasn't cheap (cost me over £30 for 2litres).
Then I used a funnel wedged between the plenum chamber and the rear of the bonnet lip, with a long piece of tube going straight down into the speedo drive hole.
Candles's method sounds a lot slicker though.
Neil
- Modificator
by Doc Fizzix » Thu 21.09.2006, 22:37
Enright13 wrote:I just changed mine, using the recommended Castrol TAF-X.
Would you recomend that for use with a LSD? I am having a hard time finding RedLine.
Also, I have always used a simple hand held pump that has two lines, an in line and an out line. Could not be simpler, place the in line into the oil container and the other line in the speed-o inlet and squeeze the handle, very simple, very clean, and very easy.
Doc Fizzix
by Doug » Thu 21.09.2006, 23:38
Doc Fizzix wrote:I am having a hard time finding RedLine.
local speed shop doesn't have it?
there's a plenty of internet stores selling it . . . .
- LEC Founder
by Enright » Thu 21.09.2006, 23:51
Doc Fizzix wrote:Enright13 wrote:I just changed mine, using the recommended Castrol TAF-X.
I'm sorry but it's not really for me to recommend
anything.
This was what I found when I did a bit of a search.
Perhaps you should email Quaife themselves - I wouldn't want to misguide you and wreck your box.
Neil
- Modificator
by Doc Fizzix » Fri 22.09.2006, 00:20
Ok, then what do those that "HAVE" a Quaife recommend? Monty? Dico? What are you guys using?
How about Moble One synthetic 75/90?
Doc Fizzix
by Doc Fizzix » Fri 22.09.2006, 03:12
Just found this and thought it was important:
GL5 is a different spec, and is not 'backwards compatible' with GL4.
GL5 gear oil is a lubricant with very high extreme pressure performance needed for Hypoid gears where sliding and rolling contacts operate under very high loadings. This is achieved by incorporating high concentration of sulfurized additives. The downside to such high sulfur in oil is it tends to corrode yellow metals, so can ruin parts like brass synchronizers and some bushings. So any equipment needing GL5 performance is designed taking this limitation of the lubricant into account.
GL4 oils are much more friendly to yellow metals, and so are used in equipment where such high load sliding-rolling contacts aren't present. The designers of such equipment aren't as limited in the use of brass parts. So the bottom line is that if your equipment calls for GL4 it probably doesn't need GL5 performance, and you may be asking for trouble down the line if you use a lube it wasn't designed for.
Doc Fizzix
by Monty » Fri 22.09.2006, 18:40
Doc, i have no experience with oils so i just went with what was recomended of this site Redline MTL which i got from
Here but as Neil quoted Castrol TAF-X should be good enough
- Chunder King!
by Doc Fizzix » Fri 22.09.2006, 18:42
Monty wrote:Doc, i have no experience with oils so i just went with what was recomended of this site Redline MTL which i got from
Thanks Monty
Doc Fizzix
by algirdas » Fri 22.09.2006, 20:07
Dear Al:
I tried to track down the Castrol TAF-X up here from a distributor in Denver and struck out big time. Redline MTL is readily available though, even in Fort Collins. If you get into a real bind, let me know and I'll pick up a couple of extra quarts and UPS them down to you.
Have you chceked the Redline web-site? They show something like 80 retailers within 50 miles of you.
Sincerely,
Algirdas
Noli illegitemi carborundum.
algirdas
by Ashaman » Fri 22.09.2006, 20:10
Ashaman
by algirdas » Fri 22.09.2006, 20:10
Dear Al:
Sincerely,
Algirdas
algirdas
by Doc Fizzix » Sat 23.09.2006, 04:48
I was in contact with Quaife and they sent me a list of recomended gear lube and they are telling me to use an ATB 70/90 GL-4. I can not find any GL-4 and I have been told NOT to use GL-5.
Doc Fizzix
by algirdas » Sat 23.09.2006, 06:07
Dear Al:
Isn't Redline MTL GL-4?
Sincerely,
Algirdas
algirdas
