paza1 wrote:Am I correct in thinking that rawlnuts are a nut embbeded into a lump of rubber and stuck into a fixing point (e.g. a hole in the body) so that a fixing point can be achieved with a suitable bolt?
paza1 wrote:If that is the case then presumeably they can be pulled out, replaced and glued back in? What adhesive?
paza1 wrote:Are they easily available or is it best to order through the usual (PMs, SJs etc).
paza1 wrote:How long are the bolts?
Dave wrote:Yes, they are essentially a brass nut embedded in Rubber. They do not require adhesive, the rubber sort of bunches up when you tighten the bolt. M100 uses either M5 or M6 depending on location. Easier to push thro' than pull out tho'
I can supply them if you want, complete with stainless bolts. Was thinking of putting together a kit for the wheel arch liners, complete with button head screws and big washers, assuming you can get the OE ones out that is!
Let me know if you need them.
