JPS M100
Postby Paul.P » Sun 08.10.2006, 14:53
ailwyn wrote:Paul,
PM me a day or two before to remind me and I'll bring along my laptop and cable.
Ailwyn
Thanks Ailwyn, that would be great !.
I have changed the plugs again, & she seems to go quite a lot better, although the plugs looked good that came out, lets see what the timing shows up ?
Postby John_W » Sun 08.10.2006, 21:32
Paul.P wrote:I did put new iridium plugs in about 4 mnths ago
Paul,
are they gapped at 31 thou?
Postby ESM » Fri 13.10.2006, 14:27
Paul just posted something that might be relevant to your problem here. Should have posted it here really but never mind.
[edit]
Here's what I posted:
ESM wrote:Regarding the relatively poor performance from Paul's car. It seems to fall behind the other from around 4700rpm which is the point where the secondary throttles are supposed to open. Its possible the actuator or the solenoid valve isn't working (bad connection, bad actuator, dislodged or leaking pipe, etc). From memory the secondaries open when you put the car into field service mode so it might be worth checking that they are actually opening correctly.
Having gone back to the manual it seems that the secondary valve will stay open rather than closed if the solenoid stops working or the actuator loses vacuum. Its still just possible its stuck closed but its less likely.
ESM
Postby Specky » Tue 31.10.2006, 00:50
how about a new project then
Postby Paul.P » Tue 31.10.2006, 08:07
Oh no Dave, don't think the wife could take the stress !
Postby Dave Eds » Tue 31.10.2006, 09:50
Paul.P wrote:Oh no Dave, don't think the wife could take the stress !
A project for YOU Paul not Mrs P :roll:
Or at least a 50/50 joint venture :lol:
Postby Paul.P » Tue 31.10.2006, 18:52
Dave Eds wrote:A project for YOU Paul not Mrs P :roll:
A 50/50 venture eh ?, whilst my lovely wife is not prone to moaning, & generally lets me do what i want, you can only push them so far Dave, believe me, she put up with a lot with Blacky, lot more than most women would of done !, anyway, i havn't finished Blacky yet ?
Postby ailwyn » Sun 12.11.2006, 17:45
JPS elanscan for people to ponder.
Paul, looks to me like your secondary throttles are opening as they should at 4500rpm.
Ailwyn
JPS Elanscan.zip
JPS Elanscan - 12.11.06
(129.74 KiB) Downloaded 194 times
ailwyn
Postby Paul.P » Sun 12.11.2006, 18:06
Ailwyn, i can't read this, unless you can tell me which programe i need to download, but any info anybody can give me will be gratefully received. One thing i did notice as i was booting it, was a quite load bang, like a backfire, & it seems to be a bit quicker now ?. Havn't had the static timing done yet.
Thanks again for doing this Ailwyn !
Postby GeoffSmith » Sun 12.11.2006, 18:29
Paul,
Download and/or open the zip file and you should then be able to save the elanscan file (jps.ecu) onto your computer. Run ElanScan and load the .ecu file (File Load) into ElanScan for viewing.
Geoff
Postby Specky » Wed 29.11.2006, 21:56
Taxing your car the JPS way
Postby Gary » Thu 30.11.2006, 12:01
I think this might be more appropriate Paul's New Tax Disc Holder
:poke: :smt043 :smt043 :smt081
Postby Paul.P » Thu 30.11.2006, 19:20
Gary wrote:I think this might be more appropriate Paul's New Tax Disc Holder
Your dead right Gazza !, saving i'm making on no smoking will pay for the next lotus !
The JPS tax disc holder is sat in my windscreen ! :wink:
Postby Dave Eds » Thu 30.11.2006, 22:06
Excel calling :poke:
Postby Paul.P » Thu 30.11.2006, 22:21
Dave Eds wrote:Excel calling :poke:
Its possible Dave ?, but also got an idea for another elan, will be mulling this over, over the winter ?, but do i want 2 elans ?
Postby Dave Eds » Thu 30.11.2006, 22:32
put them on the business books then little bruv can pay :lol: :lol:
Postby Gary » Thu 30.11.2006, 22:52
what is the problem with 2 Elans ?
Postby GeoffSmith » Thu 30.11.2006, 22:57
Gary wrote:what is the problem with 2 Elans ?
Nothing as long as one of them isn't Medina Green!
Postby Dave Eds » Thu 30.11.2006, 23:05
I feel another childish game coming on :-D :-D :-D :-D :-D
Postby Paul.P » Thu 30.11.2006, 23:58
Was thinking of buying a medina green one...................& painting it BLACK !
