by GeoffSmith » Fri 24.11.2006, 17:39
OK Bob. I'll get the soldering iron on.
Geoff
- Kitty Fiddler
by Bobc » Sat 25.11.2006, 13:35
Geoff, I guess I owe you a beer or two!!
Bobc
- Tinkerer
by JPGuillon » Sun 26.11.2006, 18:07
Hello,
Please would you put me on your list for a serial connector interface,any color will do .
Do you accept payment by PayPal ?
Thanks.
JPGuillon
by GeoffSmith » Sun 26.11.2006, 22:00
Interface list : next page!
GeoffSmith on Sun 10.12.2006, 17:06, edited 15 times in total.
- Kitty Fiddler
by GeoffSmith » Sun 26.11.2006, 22:13
Bob, yours is built but not proven (I've had problems which eventually turned out to be my laptop serial port being U/S - quiet, don't tell John_W). I hope to check it out in the next couple of days then I'll send it off. I've looked at the cheap USB to serial converter I bought and I believe it would work if it wasn't broken - it's output is OK but the input is U/S! What a weekend!:evil:
JP, I can take PayPal and should have one ready later in the week. I'll PM you details when it is ready.
Geoff
- Kitty Fiddler
by GeoffSmith » Mon 27.11.2006, 16:12
Gasser and Ailwyn : I dropped them in to village PO this afternoon but I may have missed the stagecoach - you should get them tomorrow or Wednesday.
Ailwyn - I've put a switch on the service mode plug so you can plug it in at home and let the garage change to service mode when they need to. Let me know what you think.
Geoff
- Kitty Fiddler
by GPT27 » Mon 27.11.2006, 18:15
Geoff,
Thanks for your reply to my other thread (Does ElanScan work with an N/A car).
Please add me to the list for a serial interface. My car is BRG with black interior so I'll leave it up to you to colour match me (as Trinny and Susanah seem to be busy).
I don't currently have a laptop but can probably arrange one from work.
Thanks for your help.
GPT27
by Oliver » Mon 04.12.2006, 19:11
Geoff,
Please can you add me to your list. I`ve been after a cable for a couple of years. Got an old Toshiba laptop with 15 pin serial and USB 1 but i guess serial would be better.
The Elan`s over-fuelling & i may have a fighting chance of making it run properly if i could measure some parameters. The suspects are: fuel pump, injectors, pressure regulator, ECU.
I`ve replaced anything else you may care to mention. Oh, Its another NA !!
If you can make me one i would be quite grateful!
Oliver Beames
Oliver
by GeoffSmith » Mon 04.12.2006, 20:15
Oliver, list updated. I assume it is only one you wanted!
It has been a bit temperamental on here tonight. I've got a workaround on my laptop serial port failure so I hope to have some more checked out in the next couple of days.
Geoff
- Kitty Fiddler
by GeoffSmith » Mon 04.12.2006, 20:22
Oliver wrote:Got an old Toshiba laptop with 15 pin serial and USB 1 but i guess serial would be better.
Oliver,
Serial interfaces are usually 9 pin (or 25 pin if you've got a very old computer). Could you please confirm you have got a 9 pin serial port (two rows of 5 & 4 pins, usually labelled "10101" or similar) and that you're not looking at the video output (usualy 3 rows of 5 sockets).
Geoff
- Kitty Fiddler
by Doc Fizzix » Wed 06.12.2006, 22:28
Mine came today
Thanks so much geoff
Now if I get my radiator bback any time soon I can get my car runing again and see how she works
Doc Fizzix
by Oliver » Wed 06.12.2006, 23:18
Thanks for your reply Geoff, and thanks for adding me to your list.
Yes it is a 9 pin serial port, sorry for trying to confuse you. I can send you cash or a cheque through the post when mine is ready.
I can`t wait to try it out, i need to get the thing running properly for Donington!
Oliver
Oliver
by Oliver » Wed 06.12.2006, 23:19
Oliver
Oliver
by GeoffSmith » Thu 07.12.2006, 00:04
Udate time: I've sorted my broken-serial-port-on-laptop problem and I'm able to test the interfaces out now. I've also bought in some more ALDL plugs, so by the weekend I should have managed to build up and test the 4 serial sets requested (BobC, JPGuillon, GPT27 & Oliver). I'll PM you when they're ready, then parcel them up and send them out early next week with Al's ALDL plug.
Dapinky and Ailwyn, I'll bring your interface/kit to the Queen's Head
on Monday.
Geoff
- Kitty Fiddler
by Oliver » Thu 07.12.2006, 00:33
Geoff, I`m not sure how you would like payment, would you like to email me your details and i`ll post you a cheque / cash ?
juliedbeames@blueyonder.co.uk
Oliver Beames
Oh sorry PM means private message - please excuse me iv`e been on the Heineken.
Oliver
by GeoffSmith » Thu 07.12.2006, 01:08
Oliver,
Wisely, or otherwise, I'm quite trusting and if someone says they'll buy one, I'll take them at their word and ship one before payment is sent. I'll be in touch.
Geoff
- Kitty Fiddler
by Oliver » Thu 07.12.2006, 19:32
Geoff, you are indeed a gentleman. Hopefully with the aid of your cable, the old girl may be able to return to her favouite haunt, Dungeness. (The car that is, not the wife.)
Oliver
Oliver
by ailwyn » Fri 08.12.2006, 14:19
Geoff,
Finally had a chance to test out the "paperclip" - works a treat!
Ailwyn
ailwyn
- Forum Member
by GeoffSmith » Fri 08.12.2006, 17:49
ailwyn wrote:Finally had a chance to test out the "paperclip" - works a treat!
Excellent. Thanks for that Ailwyn.
It comprises an ALDL plug and switch so you can take the car to a garage and let them set the base timing without any hassle. I'd have to cost it up, but it would only be a few quid (hundred dollars
). Does anyone else want one?
Geoff
- Kitty Fiddler
by GeoffSmith » Fri 08.12.2006, 17:54
BTW Interface list updated above.
Can those wanting serial interfaces please e-mail (not PM as my inbox is full to overflowing) me their addresses and I'll try and get them sent on Monday.
Thanks,
Geoff
- Kitty Fiddler
Return to ElanScan
