Can someone tell me where i can the find the diagnostic sockett. This is for the garage to plug in there coputer.
I think it is one of the sensors. the engine cuts off when it gets hot. That is when i have done about 30 miles . When i am stationary the revs change . i have to keep everything at high rev to keep the engine going. Really dont know what sensor it is . If its the sensor is this expensive?
rushing wrote:Having reading the treads i have noticed that Elan scan does not pick the sensor fault up.
GeoffSmith wrote:rushing wrote:Having reading the treads i have noticed that Elan scan does not pick the sensor fault up.
ElanScan will not explicitly flag up an error with the CTS, but if you log a run from cold until the fans kick in, you can look at the reported coolant temperature and it is pretty obvious whether the output is sensible (even to those who cannot yet read the runes).
rip wrote:GeoffSmith wrote:rushing wrote:Having reading the treads i have noticed that Elan scan does not pick the sensor fault up.
Hilda's CTS was not activating the engine check light before I turned up with the laptop![]()
Elanscan showed the coolant temperature as -40c
Didn't take much working out.
Sy V wrote:then turn the key to engage the starter motor.
[list=1]
[*]Entry One
[*]Entry Two
[*]Entry Three
[/list]Return to Ignition and fuelling
