Replacement thermostat
Postby Specky » Mon 31.12.2007, 12:10
Got to go down Halfrauds today...(need a crush washer)
I'll have a quick read of the book and see which cars they fit...
But the thermostat comes with seven gaskets, some with multiple bolt holes...
Stamped on the bottom of the Halfrauds item is 82 degrees C, K-2, France, Calorstat...
I hope that helps....
I' do some photos later if required...
Postby Specky » Mon 31.12.2007, 14:17
Update...
Halfords are stopping there HTK602 range in favour of the alternative QTH100 Thermostat 82° ...3 squid on tinters..
Half the price to... :-D
Has anyone tried one, do you get gaskets with it...
Postby GeoffSmith » Mon 31.12.2007, 17:19
Specky wrote:Update...
So the Fiesta boys were right.
QTH100K includes gaskets
QTH100 is just the 'stat
"How did he know?" I hear you ask. There's a link on WikiLEC of course!
Postby Specky » Mon 31.12.2007, 18:27
Cool...
So all in all..
A possitive result...
a cheaper alternative... :-D
But what's this Wiki you keep championing?
Postby GeoffSmith » Mon 31.12.2007, 19:17
Specky wrote:chamioning?
You been drinking? :-D
Postby Dave Eds » Mon 31.12.2007, 19:23
Thought he'd been leathering off his car :roll:
So to recap - which thermostat do I buy to fix the problem I had with the car on the IOM in October? :?
Postby Specky » Mon 31.12.2007, 19:56
Yep been drinking... :D
Dave Eds wrote:So to recap - which thermostat do I buy to fix the problem I had with the car on the IOM in October? :?
Any of them... :banghead: :wink:
Postby Enright » Mon 31.12.2007, 20:33
You still not done that yet?!? :roll:
Just swap it out of the other one! :wink:
Postby rip » Mon 31.12.2007, 20:34
I would go for the one with the gaskets...just in case the old ones are in bad condition when you remove the offending stat. (Rubber ones crumble apart when they get old).
Postby Specky » Mon 31.12.2007, 20:48
Gotta agree...
It's a gasket thou, not a rubber seal.... and it will be hardened...
Postby DeeAitch » Mon 31.12.2007, 20:59
geoffsmith wrote: Has anyone got an original Lotus 'stat or picture to compare against the aftermarket ones?
I've posted this before but can't find the link :oops:
OE on the left, Halfrauds on the right :D :?
DeeAitch
Postby GeoffSmith » Mon 31.12.2007, 21:00
Is that an air bleed on the OEM Dave? :shock:
Postby DeeAitch » Tue 01.01.2008, 14:35
geoffsmith wrote:Is that an air bleed on the OEM Dave? :shock:
Yes :D You will also notice it is an 'offset' design.
The Halfords one also has an airbleed - look closely and you will se a V shaped notch at the top of the valve seat.
DeeAitch
Postby Rambo » Fri 22.02.2008, 10:20
Ghost - I've just got an HTK602 ex Halfords complete with gaskets for £6 and changed it. The difference is immediate and the heater now warms up much sooner and the temp gauge has moved off the bottom stop.
Sonds like the same as your problem - my guess was that after 17 years it had given up the Ghost and was stuck in the open position ?
Postby drasicjazz » Sun 02.03.2008, 07:26
does anyone has experience with one of the thermostats on Rockauto
(under 1991 ISUZU IMPULSE RS 1.6L 1588cc L4 FI Turbo (4)
: Cooling System : Thermostat
i m looking to order on of them (specially with the dollar so cheap)
maybe this one??????????????????????????
BECK/ARNLEY Part # 1435685 ($6.4)
Thermostat, 180 Degree;Fail-Safe;Original Equipment Standard Temperature;1 Per Car [
Wholesaler Closeout -- 30 Day Warranty (Only 15 Remaining)]
drasicjazz
Postby drasicjazz » Sun 02.03.2008, 11:08
:oops: :oops: :roll: :roll:
looks like next time i shoud consider the schiping costs...........
bugger...
it was looking so good :wink:
drasicjazz
Postby dermotbell » Sun 02.03.2008, 12:26
Why the offset design?
Dermot Bell
dermotbell
Postby Specky » Sun 02.03.2008, 14:51
dermotbell wrote:Why the offset design?
It's just the design...
The OEM is offset towards one side to facilitate the use of an air bleed valve...
The air bleed valve purges air through the thermostat assembly when it is closed...
The halfords is in built..
Postby drasicjazz » Sun 02.03.2008, 21:45
somebody is selling the QTH 100 thermostat on ebay (see link)
but it's old stock (unused) ... does anyone knows if there could be any problems due to the age of the item?
http://cgi.ebay.co.uk/Thermostat-QTH100 ... dZViewItem
drasicjazz
Postby Specky » Sun 02.03.2008, 22:13
drasicjazz wrote:somebody is selling the QTH 100 thermostat on ebay (see link)
It doesn't come with a gasket, but it's the correct thermostat
Return to Engine
