by Dave M » Thu 06.07.2006, 14:34
Thanks for the info, Alan! How do you come up with the % figures you mention? Though I think I can see how the rear would be close to 11% in a standard Elan: since the valves send 20% of the braking force to the rear (and assuming you do not go over the max pressure threshold of 65/70 psi), you start at a 20% figure. Assuming pad compound is identical, the torque applied to the fronts would be slightly greater because of the rotor size (the front caliper is further out from center than the rear) - therefore lower the 20% a bit more. Maybe there is also an adjustment made due to the weight bias front/rear? Though that may limit braking ability, it wouldn't change the actual force applied to the rotor. I may be misunderstanding what you mean by "effort", however.
To help increase the ultimate work the rears are able to do relative to the fronts, I can:
1) increase the line pressure to the rear calipers
2) install a grippier rear pad
3) increase the size of the rear rotor
4) install stiffer springs in front to prevent dive and weight transfer
5) lighten the front of the car
Sound right?
All this said, Alan is right concerning a standard car with standard-spec tires. You will have a hard time matching the stock brake proportioning if you go to a big brake setup in front. However you may never use them repeatedly hard enough for it to become an issue. My issues are first, I never liked the stock brakes on a racetrack, and second, my car isn't "standard" any longer - including the tires. The stickier tires alone have made handling and braking aspects of the car change, and probably not all for the good, hence why I'm chasing brake bias at the moment.
One last note - the adjustable proportioning valves I've found so far have a max pressure reduction of ~60%, so that would send more force to the rear than stock. In a standard car, this could be too much. If you applied enough pressure to the pedal to put 85 psi to the front brakes in a stock car, the rears would see 29 psi (see table in the Service Manual, section JE page 21). With the adj valves I'm considering, the min pressure the rears would see would be 34 psi, and you could always increase that if needed.
