missys new shoes
Postby stevo » Mon 10.07.2006, 22:43
the paradas are s**t hot. i have so much more grip in the dry that it loosend my rear wheel brg's. :D happy bunny :D they work well in the wet too but most impressive is the grip off the line in the dry. :twisted:
they seem to be wearing well too :burnout:
stevo
Tyres
Postby s5tuart » Sat 22.07.2006, 17:12
Just to say that have recently put Toyo T1-R tyres all round on my S2.
Best thing I ever did and only £65 each!
For the technical out there the tyres use 2 types of compound. Squidgy in the centre and fairly hard on the outer bands. This helps avoid "tram-lining" and steering precision.
The tryes are quiet, have good wear characterictics and above all really perform on all surfaces and in all weathers. They are SO predictable unlike the previous Michelin Pilots! Urgh!
Run them all at 29 psi for good all round; try taking them up a couple of pounds if you are really pushing things.
No I don't work for Toyo!
s5tuart
Postby John_W » Sat 22.07.2006, 19:01
It's probably worth pointing out this thread about Toyo T1-R tyres. Seems not all are convinced of their merits.
Postby Paul.P » Sat 22.07.2006, 20:42
Really strange how different tyres seem to suit some, but not others. I really liked the Michelin Pilots & know Stef does to. I am running Goodyear F1's now, & whilst good, i dont think there as good as the Michelins !
Vive la difference!
Postby s5tuart » Sun 23.07.2006, 09:17
I agree. It is strange how different tyres suit different people.
I found the Pilots too prone to wild understeer. I thought they were much too hard a compound for the nimble little Lotus.
Like others I did like the Goodyears but found they tram-lined a lot and tended to squeal out their disapproval at my "exuberant" cornering, whatever I did to the pressures. I also found them fairly predictable until close to breakaway limits then they seemed to just "give up" and let go. Eeeek!
Maybe it's my driving!?! Ha ha!
Toyos for me every time. They make me look as though I know EXACTLY what I'm doing! :burnout:
s5tuart
Postby stevo » Mon 24.07.2006, 11:51
in the last 4 years i have ran eagle f1's, toyo t1-s, yoko a539's and now the paradas. i think they were all good in different areas but the parada is in another league. 8)
stevo
Postby Stef » Wed 26.07.2006, 17:43
Well I am wandering into this nasty area of tyre decision again too.
The T1 S's were great! The T1R's I found made me wobble like I was driving on jelly. After a bit of wear, a track day and swopping them to the front they seemed fine. However, a year and a half later I am needing to replace them. Guess I have done arund 25k.
The S version lasted longer and IMO looked better.
I will consider getting the R's as a pair, wearing them in on the front, swopping them to the back and then getting a second pair but would like t consider other options.
For my driving I need a tyre for all weather conditions and that has a good life span. All these fancy soft compound thingies are no good for me, I don't want to be changing my tyres every 6-12 months!
What reasonably priced options 15 inch would fall into my specification?
All 4 are thin now and will last for the Ring but no longer!
Men are like a fine wine.
Stef
TVR/PistonHeads Ambassador
Postby Paul.P » Wed 26.07.2006, 20:37
Stef wrote:All 4 are thin now and will last for the Ring but no longer!
Bloody thin, last time i looked !
colly-WOBBLES
Postby s5tuart » Thu 27.07.2006, 08:06
I had a little bit of steering "wobble" just before my last service. (One of those things you put off on a daily basis hoping the next wheel balance will cure it!)
Worryingly the garage found there was a bolt missing from the steering linkage and others were loose. (Don't ask me which ones, I'm not a mechanic) That required a change of underwear!!
Maybe that is well worth checking?
If you need to know which bolts, give John at Allon White Sports Cars a ring and ask about Stuart's Elan; I'm sure they would help you.
Despite all the negatives posted I still feel the T-1R to be the best all-rounder I have experienced. I have a colleague with a Subaru who also shares this opinion.
Finally I find the Elan doesn't take a mix of tyres too comfortably.
If I was "with funds" I would always put 4 of anything on.
s5tuart
Postby ailwyn » Thu 27.07.2006, 14:00
I've put 4 T1-Rs on my Accord and find them great, I have far more faith in them that the tyres on there before (IIRC Pirellis).
The Elan is due for a new set, so I'll be going for the T1-Rs all round.
Ailwyn
Postby Costas » Sat 29.07.2006, 20:23
stevo wrote:the paradas are s**t hot. i have so much more grip in the dry that it loosend my rear wheel brg's. :D happy bunny :D they work well in the wet too but most impressive is the grip off the line in the dry. :twisted:
Told ya ;-)
Power 362hp (437hp NOS)
Costas
Return to Wheels and Tyres
Users browsing this forum: Bella91 and 1 guest
