John_W wrote:Monty,
If you know what you're doing, yes probably.
However I had never seen the beastie before, so wanted to get it onto a bench to assess the situation.
Edited to say:
I still think it's best to take out the unit, as you have to remove three pins from the old arms for re-use, and I'd feel happier doing that on a bench & vice rather than in situ.
Two of the pins were held in by rusted nuts which required quite a bit of force to release while being held in a vice and one of them locates in the alloy casting and required gentle tapping out with a hammer while supporting the casting. If you do the work in situ there is ample opportunity for bending the arms or cracking the casting while trying to take out pins which have been in there corroding to their hosts for 15 years.
Now that I have already done the job once and know that the pins are now non-rusty and well lubricated, I might be tempted to do it in situ. However I'll never have any need to do it again as (unless you are Dave) this fitting job is a "one-off".
Bobc wrote:Dave,
Is it too late to be added to the 'Upgraded bellcrank (lazy fitters) list' please?
My cables have just broke so when the new ones arrive it would be good to install the short shift at the same time.
Many thanks,
Ghost wrote:I hope you received my payment via Paypal, and it has not gone to some disrepitable establishment in Asia!!!!!!!!!!!!!
Dico wrote:Strangely, there was no sign of any 5th gear crunching that usualy occured if care isn't taken.
“I have had the kit installed for some months now and its superb
It gets 10/10 from me”
“what an immense difference”
“The result is nothing short of a miracle. The gearshift feels like a normal car!” (My favourite)
“The combination of the AB cables, solid mounts, and short shift is nothing short (no pun intended) of making a huge difference in the fun factor of the Elan.”
"who the hell needs Bill with quality kits like this one made by a true Elan owner"
“No more rubbing elbow to the centre console when you can wrist-shift”
“You wouldn't guess from using it that it’s a cable shift at all.”
“The short-shifter is definitely a big improvement.”
“Your MK II short shift kit has transformed my car”
