lotuska wrote:The missing hole is a water one, I have also noticed that the original lotus gasket has much more re-enforcement around the various holes.
After all of my work I think I'll go safe and get a Lotus one, hopefully PM will have one in stock.
geoffsmith wrote:Is there a hole missing from both gaskets in the same position on the top cylinder?
geoffsmith wrote:Is the build up in crud on the old gasket because the hole in the head is circular?
geoffsmith wrote:geoffsmith wrote:Is there a hole missing from both gaskets in the same position on the top cylinder?geoffsmith wrote:Is the build up in crud on the old gasket because the hole in the head is circular?
dapinky wrote:The insert pushed out with finger pressure easily.
Monty wrote:Don't think i would recommend removing the metal ring as it's very close to another hole only IMHO, i removed the locating dowel on that side. It's wierd that one locating hole fits but the other doesn't
geoffsmith wrote:Monty wrote:Don't think i would recommend removing the metal ring as it's very close to another hole only IMHO, i removed the locating dowel on that side. It's wierd that one locating hole fits but the other doesn't
If you check out Mark's colour coding, it's only a bolt hole next to it and there is a seal around both so I don't think it's a problem. Like you, I was sceptical but yet again Pinky is right!
dapinky wrote:I had the same issue with the one i used (NOT from kmc, but from USA, destined for an impulse turbo). i can only assume that Lotus used a slightly different head locating dowel system than Isuzu,
