Dasboard/Instrument Lights - replacement bulbs?
Postby bunglin » Tue 21.08.2007, 13:44
Does anybody know if there is a list of replacement bulbs for the dashboard and instrument lights?
I have just replaced my boot light with a new bright white LED one as the old bulb was very dim - and eventually blew. When I looked at the bulb - the glass was coated in a brown/silver coating that must have been dimming the light and i'm wondering whether some of the bulbs in my dash are doing the same thing. Some of my dash lights are very dim (especially my main beam) and so would like to replace them with something a bit brighter.
I did have the electrical and service manual pdf's at one point but seem to have misplaced them and cant find the download links again. I assume they would be in there - along with replacment instructions.
bunglin
Dashboard/instrument lights
Postby Ghost » Tue 21.08.2007, 19:17
I obtained replacement bulbs for the dash display and warning lights ( two different wattage bulbs) from the local Vauxhall spares counter!
Cannot remember the cost, but it cannot have been much as I replaced all the bulbs when having the dash out for some work.
Spending the kids inheritance
Ghost
Postby DeanG » Mon 03.09.2007, 21:23
In my search for instrument lights I found the “Bulb & Holder, tell-tale lamps” part number: A100N6012S Remarks: Black 1.2W (from Page 1 17.07A of the parts manual) at a BMW dealer. The BMW part number is: 62-11-1-368-299 and it is an exact replacement even having the same manufacturer - OSRAM. Note that the black referred to is the color of the plastic surround.
I still haven’t found a replacement bulb for the green base 2W bulbs.
DeanG
Postby Gee0 » Thu 06.09.2007, 22:58
I have just replaced all the main bulbs in the dash i.e speedo revcounter etc. and FBT aswell as the heater.
The FBT and heater bulbs are all the same just a push in. The turbo guage is the most difficult but a sharp nosed pilars did help.
The bulbes for the ignition lights are 12v 1.2w (black) osram the same wattage as the FBT.
The ones for the instrament panel are 12v 2w (green) these are much harder to get hold of, so for the moment I have replaced them with the BLACK ones. The dash is just not as bright are the FBT but there is little difference. The only reason they are a higher wattage is that they have a greater area to light ( 4 for the main instrament panel). again this is quite easy to do just a 1/4 turn to unplug. Just a TIP unplug the electric plugs as you go to make room. I did them all in about 20 min at the most.
I will sort out part numbers in the next few days and they should be able to be got at any independant motor factors. (I got mine in Ireland) Even the national suppliers did not have the 2W (green) bulbs in stock.
Gee0
Postby donsladek » Mon 08.10.2007, 02:43
From research on the Web:
The green base instrument panel lamps (12V 2 Watt) appear to be:
Volkswagon 893 919 040A or Osram 2352MFX6 or Flosser 439103
The black base instrument panel lamps (12V 1.2 Watt) appear to be:
VW 893 919 040 or Osram 2351MFX6 or Osram 2721MF or Flosser 419103 or BMW 62 131 1 383 311
The base type is B8.5D.
Use caution, as these have not been verified.
Don Sladek
Don Sladek
Calypso Red '91 #37594
donsladek
Postby GeoffSmith » Sun 25.05.2008, 21:13
Gee0 wrote:I will sort out part numbers in the next few days and they should be able to be got at any independant motor factors. (I got mine in Ireland) Even the national suppliers did not have the 2W (green) bulbs in stock.
These are type 286 capless and are 17mm x 5mm dia. I bought some from a local motor factor for £1.30 each.
Postby Gee0 » Mon 23.06.2008, 19:11
Nope not those ones they are for the general dash (behind the FB3 and the heater controls)
They differ to the bulbs needed for behind the speedo ect. IIRC they should be Green which are a 2w but the only ones I could get hold of are Black which are 1.5w. (the Green ones are the bulbs I was refering to as being hard to get hold of. There seems to be plenty of black ones around)
The Black ones look fine just a little dimmer than the rest of the interior lights.
Hope thats as clear as mud!!!!!!!!
Gee0
Postby BFG in the BRG » Wed 02.07.2008, 18:24
I've just ordered some from this lot, having tried 3 different places and ebay without success - https://www.autobulbsdirect.co.uk/ £7.50 for 10, green 2W and black 1.2W, with free postage and paid via Paypal. :lol:
Go to the Standard bulbs section and the drop down menu for dashboard bulbs
Green 2W R509TGR
Black 1.2W R509T
They haven't said either are out of stock :shock: so fingers crossed.
I'll let you know when/if they arrive 8)
PASH
Alas soon to be Elan-less
BFG in the BRG
Postby Elanlover » Fri 04.07.2008, 21:25
Plenty of good LED based options for these too.
Postby BFG in the BRG » Sat 05.07.2008, 12:44
Will the LED's dim though?
BFG in the BRG
Postby Elanlover » Sat 05.07.2008, 18:29
BFG in the BRG wrote:Will the LED's dim though?
They dim plenty good. :-D These are excellent and the best LED dash lights I've bought so far. And believe me, I've tried them all. :roll:
Postby BFG in the BRG » Mon 07.07.2008, 18:08
Thanks for that, my bulbs heven't arrived yet (mind you it is less than a week so far), if they're out of stock I'll probably buy those crazy LED ones - I presume you go for red ones for the standard orange gauges being as LED's generate light at a specific wavelength :?
BFG in the BRG
Postby Elanlover » Mon 07.07.2008, 18:25
Well, my dash is now custom with Metal Monkey dial faces that require a little bit different lighitng in therms of colours. For the stock faces I would think red woiuld do just fine. White might actually change the colour to moe of a light oraneg where as the red would probably make the dials look a bit more red than orange. I also aded one bulb at the top of the cluster (drilled a hole and ran two wires) to give a bit more light as the LED's tend to be more uni-directional and incandescants are more omni-directional.
Postby Neil D. » Sat 12.07.2008, 11:58
I have just replaced the bulb that illuminate the temp and fan switch.
I used the write up on wiki
http://wikilec.9600.org/index.php/Repla ... itch_Bulbs
However two things to add.
Yes the bulb holder does fall into the void behind the panel, but is easily retreivable. Just remove the trim panel under the steering wheel ( two screws) and you can get your hand in to re position them ( I have big hands )
Second on the S2 the bulbs are covered with a red "condom" this was available at the french motorfactors.
Hope this helps
Neil
Neil D.
Re: Dasboard/Instrument Lights - replacement bulbs?
Postby shakadad » Sun 03.11.2013, 03:54
I am trying to find the boost gauge bulb in the U.S. Any advice on how and where to do that? LED replacements might be fine also. Thanks!
shakadad
Postby Brit-Car-Nut » Sun 03.11.2013, 07:05
per the WikiLEC: 286 capless 1.2w - Try a Volvo dealer for a quick find or order from Amazon UK or eBay UK. They come in colors too, so make sure you order what you want.
Lotus Parts book says the 4 gauge bulbs are 2W and Green. Part # A100N6013S Now Obsolete
They are listed in the DBE price book for $1.86 Maybe they have some?
T5 LEDs listed on eBay. Look at item number 170877301844 for a list of bulbs it replaces.
Postby TrevorB » Tue 04.03.2014, 22:53
When driving back last week from garage after service and MOT, at night, I noticed that the backlight for oil
gauge and half of rev counter had gone out. Can I access these via the instrument binnacle to check if just
loose connection or whether bulbs need replacing :?: Or is it more complicated than that :?: If the bulbs
do need replacement where's the best source nowadays :?:
As always thanks for your help
:cheers:
HiSpec front brakes
PNM rear brakes
Aluminium radiator
Closed Loop conversion
Kilimanjaro chip
Wannabe Princess
Postby Rice crispy » Tue 04.03.2014, 23:42
Trevor you get access from the top of the binnacle. There are 2 screws and then you lift the back and slide it towards the screen the you can see/feel the rear of the gauges to get to the bulbs. I got mine in halfords or local spares shop
[/b]
TrevorB wrote:When driving back last week from garage after service and MOT, at night, I noticed that the backlight for oil
:cheers:
Rice crispy
Postby TrevorB » Fri 07.03.2014, 10:54
I've investigated the problem and found a loose connection on the oil gauge lamp holder whilst refitting the lamp flickered and then
nothing, heard a click and now all the instrument lights have gone out. Looking at fuse diagrams on wiki I cannot identify a specific
fuse that covers the instrument lights. Fuse 3 in Box C states RHD CDL, what is that for :?: Or is there another problem I need to
investigate :?:
There are no other problems and car is otherwise working fine.
Thanks for your help, as always.
:cheers:
HiSpec front brakes
PNM rear brakes
Aluminium radiator
Kilimanjaro chip
Wannabe Princess
Postby Elanlover » Fri 07.03.2014, 13:17
TrevorB wrote:I've investigated the problem and found a loose connection on the oil gauge lamp holder whilst refitting the lamp flickered and then
investigate :?:
:cheers:
Trevor, the CDL fuse is for the central door lock module - not applicable if you have an S2. I don't recall which fuse covers the instrument cluster lights but have a look at fusebox A in the passenger's footwell, #4 (RHD lighting). Could also be #12 (battery services).
