by MattDon » Fri 07.12.2007, 11:12
ok ive had a search and couldnt find it so apologies if im going over old ground but, ive never changed popup headlight bulbs, and im perplexed as to how to do it.
MattDon
by Enright » Fri 07.12.2007, 15:06
I've found it best to manually wind the pod up half way then reach in from the side while looking through the slot at the top.
Still helps if you have about 3 elbows though.
Neil
- Modificator
by M100 TWO » Fri 07.12.2007, 18:09
Wind the pods up, there are three screws in the front of the reflector unscrew do not confuse with the three adjustment screws and remove whole reflector from inside the pod place in your lap and change the bulb making sure it is seated properly
john
M100 TWO
by Rambo » Fri 07.12.2007, 20:18
Enright wrote:I've found it best to manually wind the pod up half way then reach in from the side while looking through the slot at the top.
3 elbows, 3
small hands and lots of swear words.
It should be easy but rarely is. It's one of these jobs that you can get right 1st time or spend absolutely ages - particularly with the spring clip.
Good luck and don't forget a hot bath for that sore back and strained hamstrings
- Don't push me
by nicehex » Thu 10.04.2008, 12:50
Thanks for the 'halfway up' tip!!
Foolishly thought it was a straightforward job and spent some time cursing and trying to force my big hands into a very small space before I looked here..
Cranked 'em halfway and it took me 5 mins - that'll teach me.
Thanks again.
nicehex
by GeoffSmith » Sat 12.04.2008, 07:59
Also showing at a
WikiLEC near you.
- Kitty Fiddler
by LittleRob » Sat 26.07.2008, 09:53
Thanks guys. I was just able to fix my headlight. Actually not the bulb in the end, just a bad black (earth ?) connection I think. Took it out, looked at it, put it back = success.
I never knew that they could be wound up manually. That'll no doubt come in useful next time they are at half-mast !
I just used my spindly fingers. I couldn't get more than 1 screw undone - even with WD40
LR
LittleRob
by Mikee » Sat 06.09.2008, 00:31
Rambo wrote:Enright wrote:I've found it best to manually wind the pod up half way then reach in from the side while looking through the slot at the top.
3 elbows, 3
I did mine in a matter of seconds. (brag brag, got to i'm a mechnical idiot, so this is the glory) First time, no swearing (theres a nice change) maybe I got lucky. Chainging the beam lights will be a different story as the reflector is vitually non existent and will probably just falls to pieces the moment i breathe on it....
Mikee
by GusMangoFish » Fri 02.10.2009, 17:55
Have just changed my headlight bulb for the dipped lights. Took about 10 minutes in all to remove the old bulb and replace with the new. I found a mixture of having the headlight wound almost halfway up and reaching in from the side, then all the way down again and reaching in from behind, resulted in the best access.
I unfortunately broke one side of the spring clip as it was pretty brittle. It seems that it's still going to hold the bulb in place securely enough though.
If it's helpful for anyone, the bulb I used was: Eurolec 448 12v/55w H1 P14.5S
This was available off the shelf at my local Lotus dealer, and I'm assuming is a relatively standard bulb? (I don't know anything about bulb types).
GusMangoFish
- Tinkerer
by JPope » Sat 08.11.2014, 16:39
Are the us model different? I ask because i have tryed everything and all different positions and it just not coming out. I have no access from the back only the front and side.
JPope
by Brit-Car-Nut » Sat 08.11.2014, 20:17
Yes, the FED headlamp is different from the UK version since the Fed used a SEALED Beam - the entire glass unit gets replaced and the UK ones just have a bulb that can be removed like a tail light bulb.
You will need to release the actuating link and unbolt the main hinge so you can take the entire headlamp housing off the car. Of course, you will need to remove the plugs at the bulbs and I believe there is a clip that keeps the harness in a safe location that will need to come off too.
The main hinge is shimmed to fit the car, so make sure you put the correct shim pack back at the correct mounting bolt.
