Cambelt etc
Cambelt etc
Postby clan » Sat 19.04.2008, 20:49
I'm looking to order a new cambelt and water pump etc from Rock Autos, could someone have a look at my list and see if it looks okay. I managed to pick up a discount code as well. What is the best postage method to use to try and avoid the import taxes. :wink:
Engine : Timing Belt
GATES Part # T169 {Automotive Timing Belt 1" x 50 3/32" (159 Teeth)} $13.03 $0.00 1 $13.03
Cooling System : Water Pump
BECK/ARNLEY Part # 1312115 $50.79 $0.00 1 $50.79
Cooling System : Water Pump Gasket
BECK/ARNLEY Part # 0394100 $2.10 $0.00 1 $2.10
Engine : Timing Idler
GATES Part # T42001 {Timing Belt Pulley Steel Smooth (60mm x 10.4mm x 31mm)} $42.79 $0.00 1 $42.79
Engine : Timing Belt Tensioner
GATES Part # T41027 {Timing Belt Tensioner Steel Smooth (60mm x 10.5mm x 30.5mm)} $46.79 $0.00 1 $46.79
Subtotal $155.50
Discount -$7.78
$72.06
Total $219.78
1992 SE - Monaco White - 64,000 miles and climbing.
White Is The New Black.
clan
Postby dapinky » Sat 19.04.2008, 21:32
Clan,
You can save a couple of bucks - the water pump comes with a gasket, there's no need to get a seperate one.
Postby John_W » Sat 19.04.2008, 21:35
Clan,
Have a look at Hegg's thread here for the number references.
GATES T169 AUTOMOTIVE TIMING BELT $18.78 OK
FELPRO 18-648 NEW WATER PUMP (Note: 8-97031-473-0 1.6l (1588cc) dohc) $44.53 ??
FELPRO 35454 WATER PUMP GASKET $2.58
GATES T42001 TIMING BELT PULLEY $46.26 (idler) OK
GATES T41027 TIMING BELT TENSIONER $50.88 OK
The Felpro option doesn't come with a gasket but it looks like original equipment and even with paying for agasket is no dearer.
Sounds like prices in the USA have actually come down since Hegg ordered the bulk buy.
You might want to add:
GATES K040270 AUTOMOTIVE V-RIBBED BELT (STANDARD) (alternator) $6.97
GATES K060415 AUTOMOTIVE V-RIBBED BELT (STANDARD) (air con & power steering) $14.36 (or get one from SJ if you have no air con)
They fit - I replaced mine two weeks ago (except the water pump) and the car runs fine.
Postby theelanman » Sat 19.04.2008, 21:49
dapinky wrote:Clan,
that looks exactly like the list I did from Rock...and as pinky says...it comes with the gasket......I was unsure at the time so rather than found out it didnt have one I thought it easier to add it in the order :-D
Postby clan » Sun 20.04.2008, 11:26
Thanks guys, I will delete the gasket and add the alternator belt. :D
clan
Postby rip » Sun 20.04.2008, 23:23
clan wrote:Thanks guys, I will delete the gasket and add the alternator belt. :D
& the PAS one too? :wink:
Postby clan » Sun 20.04.2008, 23:35
Should I consider getting that done as well, I don't have aircon so it would be SJ's for that then.
clan
Postby Monty » Mon 21.04.2008, 16:39
Clan,
If getting the Alt & PAS pushes the postage price up with RockAutos don`t bother ordering them as you can get them from your local motor shop. In the UK the Alt belt is a about a fiver and the PAS belt about a tenner.
Postby GeoffSmith » Tue 22.04.2008, 23:36
Check the Wiki!
Postby Rambo » Wed 23.04.2008, 10:32
Clan - if you haven't ordered already, I'm happy to come in with you in an effort to keep postage/customs charges as low as we can - economies of scale and all that.
For instance if we order 2 of everything and only 1 aircon/PAS belt for me, then the postage charges are only $112.53 as opposed to $104.56 for ordering 1 of everything :shock:
It doesn't look like you need the w/p gasket so I didn't include this in the pricing.
Let me know if you want to go this way? I can process the order with a VISA card if you wish and we could arrange a mutually agreed exchange (Knovckhill services ?) of parts and cash etc
Postby clan » Wed 23.04.2008, 13:21
Rambo, you have a PM :D
clan
Postby dapinky » Wed 23.04.2008, 18:29
Rambo wrote: I can process the order with a VISA card if you wish
Just to let you know, they do take paypal for an instant www order confirmation!
Might be of use if you don't want your visa card details in an insecure e-mail, and don't want to get up at stupid o'clock to speak to someone in a different time zone.
(and they don't charge extra %% for accepting it)
Postby Rambo » Thu 24.04.2008, 10:04
Thanks Dave - I hadn't realised there might be a problem with VISA.
I'll have a re-think as I don't use PayPal
PS Had a look at JohnW's list and the Felpro water pump no longer appears to be available via RockAuto
Postby theelanman » Thu 24.04.2008, 13:35
dont forget to do a search for the rock autos discount code thing on here....
another 5% off IIRC
cheers
G
Postby Rambo » Wed 30.04.2008, 14:19
theelanman wrote:dont forget to do a search for the rock autos discount code thing on here....
another 5% off IIRC
cheers
G
Thanks Gareth - I'd already done a bit of searching around and found this http://www.retailmenot.com/view/rockauto.com address for up to date discount codes in case anyone else wants to order anything in the near future ?
Postby Rambo » Tue 13.05.2008, 20:45
What a brilliant sevice from RockAuto in the States. :clap:
Oredered all the bits for a timing belt change for me and Clan last Wednesday, got e-mail confirmation that parts were on their way on the Friday in 3 deliveries via Fedex.
First delivery was on Monday, 2nd delivery today. Just awaiting the water pumps now - hopefully they will arrive tomorrow.
Postby Enright » Wed 18.06.2008, 18:14
firebobby wrote:I checked the service history today and found the timing belt was done at 72k miles. That's good I thought it's only done 98k miles now. But looking closer 72k miles came up in 1998!!!!!! So it's in tomorrow for an ADL kit. Been told £230.00 all in (4 hours labour) so not to bad for the piece of mind.
dave. :)
I've got my broom out again... :wink:
Postby Stef » Wed 09.07.2008, 14:12
Ah! I hope to add to this thread.
Blipi's recent service has pulled up a few things. Most annoyingly it was found she has a hole in her cambelt! :shock: It was only changed 4 years ago!
The garage have recommended I also go for tensioners and other bits.
Not being very technical or mechanically gifted, can I ask for advice on what actual bits are required or recommended and best place to find them? RockAuto's seem to be the supplier of choice here however I'm not needing the other water pump bits (or so I think...)
Cheers in advance! :-)
Men are like a fine wine.
Stef
TVR/PistonHeads Ambassador
Postby dapinky » Wed 09.07.2008, 21:00
Steph,
Far be it for me to tell you how to spend your cash (or JB's!), but if your going for the belt and tensioners, I would say throw in a water pump as well (its about 25 quid).
The bearings are likely to wear at a similar rate to the tensioners, and it all has to come off to change the pump anyway, and will take about an extra half an hour to change (mostly spent scraping the old gasket off!).
All just IMHO!
Postby Stef » Thu 10.07.2008, 09:05
Thanks for the advice.
As I ahve no intentions of selling Blipi I guess that will be the best tactic to take.
Cheers!
Stef
