Halfords Black goo
Halfords Black goo
Postby nickb » Fri 20.05.2005, 11:34
I'm sure one day while surfing on LEC I see a post mentioning a black silicon Goo Halfords sold, I think there was even a picture of the packet but I can't seem to find it anymore?<br><br>Am I going mad, or just very bad at finding things<br><br>Nick
nickb
Re: Halfords Black goo
Postby Sy V » Fri 20.05.2005, 12:35
Try searching by "sikaflex" that's the brand name of the real McCoy.  I'm assuming you're alluding to Halfrauds equivalent.
Postby nickb » Fri 20.05.2005, 13:22
Thanks Sy.<br><br>I need  it to fill the channel that is filled with a black rubbery substance down both sides of the windscreen.<br><br>I presume Sikaflex will be ok for this????
nickb
Postby Enright » Fri 20.05.2005, 13:28
Do you mean Halfords Black Silicone Sealer? I think a 40g tube costs about £2. It's in a 6" long green tube with a white cap.<br><br>If you need I can send a pic.
Postby Sy V » Fri 20.05.2005, 13:33
Sikaflex comes in a variety of guises. IIRC it's the black marine sealant you need with a combination of 2s and 1s in its title.<br><br>Anyone?<br><br>That said, the Halfords equivalent is much cheaper.
Postby nickb » Fri 20.05.2005, 13:34
that's the one, I knew I hadn't dreamed it.<br><br>Nick
nickb
Postby nickb » Fri 20.05.2005, 13:37
sorry, yes please enright as my local Halfrauds doesn't seem to stock it.<br><br>Nick
nickb
Postby theelanman » Tue 11.10.2005, 11:47
if halfrauds dont do it anymore then try this lot
Sikaflex 221-This old favourite, now replaced by Sikaflex 291 for marine applications, is still available to order apparently.
https://www.fluke-motorsport.co.uk/cata ... cts_id=203
http://marinestore.co.uk/Merchant2/merc ... e=sikaflex
http://www.boatpaint.co.uk/acatalog/Boa ... s_224.html
http://www.western-marine.com/page90.htm
http://www.cfsnet.co.uk/acatalog/CFS_Ca ... 1_160.html
http://www.boatsandoutboards.co.uk/view/CRM012/
http://www.mailspeedmarine.com/brandlis ... /Sikaflex/
just a few to be going on with.....the one SY awas on about is 221 but if you cant get that then 291 is it new uprated version...failing that I reckon that 90% of these sikaflex products are useable for 'land' application
cheers
G
goo
Postby theelanman » Sat 15.10.2005, 17:29
just been to halfrauds...
its now a loctite product..40ml tube....£4 a go
called loctite superflex black
halfrauds cat number 24802
hope this helps
chers
G
Postby max and andy » Sat 13.06.2009, 09:52
I remember reading a post where clingfilm was used to deal with Sakiflex when patching your seals but i can't remember how it was used. A&m
max and andy
Postby GeoffSmith » Sat 13.06.2009, 10:14
Andy, try typing "clingfilm" into the search box and you'll find posts like this!
