Having fitted a large (2-1/4") exhaust to my car, I performed some dyno runs yesterday (http://www.wallaceperformance.co.uk/home.html) to acquire data to answer the question of whether or not a big exhaust is worth it. (I do notice a difference on the road.)
So far the only similar published data I know of is from Philbo (http://www.informatica.zen.co.uk/elan/Exhaust.htm) where he reports gains of 40 bhp and 30 lb/ft from fitting a Paul Matty exhaust (225 bhp from BBR + exhaust - http://www.asnu59.dsl.pipex.com/elan/gr ... torque.jpg). This compares with my own results of a 21 bhp & 11 lb-ft gain (215 bhp from an older V3 version of the Everest chip + exhaust), and more impressive gains when using the standard chip (because the exhaust induces overboost). I have not yet tested the latest Everest chip (V4.2), however I expect even more impressive results.<br><br>I performed two dyno passes, one with the standard and one with the (old version) Everest V3. Values are "at the flywheel", having performed "rundown" back to idle with the dyno and car free-wheeling to measure transmission losses. Results are displayed on the graphs:
I logged ElanScan during the dyno runs. It never ceases to amaze me how useful this brilliant piece of software is. Several interesting things showed up, as can be seen by the following annotated graph from the session.
http://www.asnu59.dsl.pipex.com/elan/gr ... _25feb.jpg
Some points to note are:
- The Everest boost goes up to 0.88 bar.
- The standard chip develops greater than standard boost owing to boost creep attributable to the 2-1/4" exhaust. Boost can be clearly seen increasing from the standard 0.6 up to 0.8 (then falling off). This shows that power can be increased by fitting a big exhaust (but only if you wait for the creep to take effect).
- Data I collected supported those collected by Philbo. The new exhaust was worth it:<br>Flywheel power with the standard chip was up from 155 @ 6000 RPM at the flywheel to 202 @ 7000 RPM (194 @ 6000 RPM). <br>Power from the V3 Everest was up from 194 @ 6000 RPM to 215 @ 7000 RPM (199 @ 6000 RPM). This seems like a big increase to me from just fitting an exhaust.
- The air/fuel mix at full throttle is way too rich (measured by a lamda sensor in the exhaust pipe). The dyno owner thought the car would benefit from some revision of fuel mapping, and I believe him.
- I was impressed by the dyno and workshop and will go back (to test the Everest V4.2).
I am still puzzling over the very high power and torque levels and over comparisons with my previous dyno run data and those collected from others. Once I've had a think and checked them, I'll post my conclusions.
I hope this has been useful and that you will all post your dyno results.
