Turbocharger wrote:I may be going further into the dark side then I originally intended.
First of all the Honda that outputs 400hp with no "juice" is doing so at 8000+rpm, keep that in mind, there is NO way to acomplish such hp on the Elan (with no juice) at 6300rpm (area of max power).
Above all, unless you install Quaife, and you do MAJOR upgrades on suspension, you wont be able to really use that power and on top the car will substeer on bents because of the stupid spinning.
Out of my experience since I used-driven-racetracked the Elan in various Hp versions the best HP for our car is NO more than 250.
Yes at 300 or 350 or 400 the car is unbelievable fast and the feeling of acceleration is priceless, BUT you DO have bigger lag no matter what and therefore the car is turning to a straight line car than for race track use.
davidjt wrote:I've probably missed this somewhere, but what are you 300+ guys using for a clutch?
Can't you get that with the T3-style outlet with no flapper valve?
