CTS
CTS
Postby ESM » Tue 06.09.2005, 19:04
Pretty confident the CTS is a:
GM 25036979 [correction: its an AC Delco part no. not a GM one]
Opel 1338450
The calibration tallies exactly (see here ). Its also used on the Lotus Carlton and the Fiero.
ESM
Postby ESM » Tue 06.09.2005, 22:00
Ok I'll un-correct my correction above - GM use the Delco part number, as do Daewoo. Here are the part numbers from a couple of other makes:
Isuzu: 8250369790
Chrystler: 33004281
Its also used in these applications:
Opel Monterey 3.2 V6 24V 92-95
Isuzu Rodeo 3.1, 3.2 V6 91-94
Isuzu Trooper II 3.2 V6 24V 92-95
Isuzu Pick-up 3.1 V6 91-95
ESM
Postby Jeffbro » Wed 19.10.2005, 20:57
Thanks for the info, I can confirm that the above mentioned GM part no came up trumps at my local auto spares and is now fitted and working fine! Cost £16 as apposed to £45 ish from you know who! :D
Jeffbro
Postby Monty » Thu 20.10.2005, 00:18
Not bloody Halfords :?
Postby Oliver » Sun 29.01.2006, 21:09
Just bought one of these from a Vauxhall dealer. The part no. changes to 015326386 and it`s in Isuzu packaging.
Oliver
Postby Ekapol » Mon 30.10.2006, 22:46
I found this information searching on Isuzu part site:
Part number 8250369790 was superceded by part number 8153263860.
Ekapol
Postby Ekapol » Tue 31.10.2006, 00:29
CTS connector should be included here I think, same size as the IAS connector.
CTS Connector
Get the pigtail version, $7 more. IAS with pigtail will be $4.50 more :? But the guy said CTS connector will have the plastic key to make the connection tighter.
Ekapol
Users browsing this forum: Bing [Bot] and 2 guests
