Fuel Filter Replacement P/N
Postby Houdini » Sun 26.02.2006, 21:35
AC P/N# GF-481 or Purolator P/N# F33144 After accessing use a 20mm and 16mm wrench to remove/install. The clamp holding it place has 2 10mm bolts remove these after loosning the fittings.
Houdini
Postby algirdas » Wed 01.03.2006, 05:07
All:
Here are some additional possibilites. Note: I got these cross references from a friend at Advance Auto Parts. I DO NOT know for a fact whether they work or not. Caveat emptor!
AC Delco GF-651
Purolator F33144
Motorcraft FG851
NAPA 3481(BP)
Bosch 0450905177
WIX 33L481
Champion G481
Deutsch FF504
Hasting GF111
Isuzu 8-25055-052-0 or 8250551290
Lucas F157
Cost from Lotus for an AC Delco Unit from England is $33USD. Cost from Advance Auto Parts for a Purolator is $6USD.
Also, for whatever it is worth, rumor has it that the filter element is the same as a V/8 Esprit as well as most every fuel injected GM product.
Sincerely,
Algirdas
Noli illegitemi carborundum.
algirdas
Postby atikovi » Mon 18.09.2006, 19:09
You may also need to replace the 2 o-rings on the fittings going into the filter. GM part number 22514722 at about $1 each.
atikovi
Postby Ekapol » Tue 03.10.2006, 02:54
I have just recently ordered SJ910E0005FUEL FILTER (Delco injection) from SJ Sportscar at 8.30 GBP. Don't really know if I need to get it replaced or not but just in case it's an easy job to do when I have Marie's rollbar fit.
Ekapol
Postby M100 TWO » Wed 07.03.2007, 15:05
Man fuel filter No WK612/2 OE on German cars
O rings from MG Rover pt No EDP9976
I have four sets of O rings, i had to buy 10 min order.
£1.10 a set at Donington on Saturday or a complete package filter
plus O rings £13.20
john
M100 TWO
Postby paulwatkins » Wed 07.03.2007, 15:22
M100 TWO wrote:Man fuel filter No WK612/2 OE on German cars
plus O rings £13.20
john
John, can I take a complete set (filter and o-rings) off you at Donny please?
Paul
paulwatkins
Postby Dico » Wed 07.03.2007, 16:34
Complete set for me also please John.
I've ordered that much gear of so many people, I just hope I remember on the day :?
Postby dapinky » Wed 07.03.2007, 16:58
plus O rings £13.20
john
John, just a set (pair) of 'O' rings please - i picked up a filter (FRAM part number G3727) on Monday and didn't even think about the rubber bits!
(but it was a good price - £5.55 + VAT)
Postby Ekapol » Wed 07.03.2007, 22:04
Hi John,
I ordered the Delco but SJ shipped me FRAM's.
Could I have a set of O-ring too. Please PM me how I could make the payment (Paypal, etc)
Thank you,
Ekapol.
Ekapol
Postby GeoffSmith » Wed 07.03.2007, 22:19
Not trying to do John out of a sale, but is it cost effective to send O rings across the pond? If they are standard circular section O rings, then all that is needed is the inside diameter and thickness (or am I missing something?). I nearly bought a box of O rings from Pirtek when I had my PAS pipe made up to save the delay and hassle in getting them from the accessory shop (20p each last week).
Postby algirdas » Wed 07.03.2007, 22:51
Dear Ekapol:
I'm with Geoff on this one. Cruise on down to Harbor Freight and pick yourself up a couple of boxes of "O" rings. Should last you a lifetime for around $20. I got the metric and inch sets. See
http://search.harborfreight.com/cpisear ... eSearch.do
I'm doing my fuel filter either tonight or tomorrow night. I'll let you know how it goes.
If you really want the real deal from the UK, I can bring them home with me and just drop them in the mail to you once I am back stateside.
Sincerely,
Algirdas
algirdas
Postby atikovi » Wed 07.03.2007, 22:57
...pick yourself up a couple of boxes of "O" rings. Should last you a lifetime...
Most o-rings are made from some type of rubber that ages and gets hard with age so unless you are planning on leaving anytime soon, I would only buy enough for a few years worth.
atikovi
Postby algirdas » Wed 07.03.2007, 23:09
Dear Atikovi:
You are absolutely correct. I meant that figuratively, but in my defense, I still have Twincam water pump "O" rings that are still usable after 20 years (though I probably will not risk using them).
But we are talking about Ekapol here and, even though all of our days are numbered, in Ekapol's case that number is much lower than most. Remember, he bought Doug's car.
Just kidding.
Sincerely,
Algirdas :D
algirdas
Postby GeoffSmith » Wed 07.03.2007, 23:16
Algirdas :smt043
The two places I bought from had the same case advertised in the Pirtex catalogue and they were not new! Available for £15 for 400 and worth it for the time saving alone.
Postby M100 TWO » Thu 08.03.2007, 11:25
the size of the O ring is 5/16 ID---7/16 OD hope this helps our friends over the pond who don't have the luxury of a Rover garage at hand
john
M100 TWO
Postby DeeAitch » Thu 08.03.2007, 13:05
Be careful when selecting 'O' rings, material is very important, especially when fuel is around! e.g. my garden hose connector has O rings which barely last one year and that is with water and a (little :lol: ) sun :shock:
For instance James Walker
supply our 'O' rings in over 100 general and high-specification grades of elastomer (and other materials) including ranges of low-temperature and explosive decompression (ED) resistant materials.
Some reading for you:
O rings
DeeAitch
Postby GeoffSmith » Thu 08.03.2007, 14:13
:oops: Very true Dave. My links were for Nitrile which are suitable for fuel and oils.
Postby M100 TWO » Fri 09.03.2007, 19:40
Paul watkins ,Dico ,Papinky parts in the boot of the car already so I cannot forget them
john
M100 TWO
Re: Fuel Filter Replacement P/N
Postby Ekapol » Thu 15.03.2007, 21:25
algirdas wrote:in Ekapol's case that number is much lower than most. Remember, he bought Doug's car.
I'm aware of that :o
Thanks all for the reply, and the links. I will read some more about o-ring and will probably go to a part store nearby.
Cheers,
Ekapol
Postby Doug » Fri 16.03.2007, 01:32
Ekapol,
the fuel filter was replaced once while I had her -- either when the fuel tank was replaced or more likely when I had the fuel sender assembly replaced -- see the records for the date/mileage/info :wink:
