algirdas wrote:So once I free the outboard end from the bearing carrier and it is hanging free, I go to work on the inboard end. How "medieval" can I get on it? Are there seals that I need to replace at the transaxle while I am there?
And now for the driver's side. Once I have the outboard end free of the bearing carrier, how tough is it to get the inboard end over the round split ring? Again, how brutal can I be with it? How brutal do I have to be with it?
algirdas wrote:I was under the impression that I leave the center bearing carrier in place and separate the driveshaft at that point from the center bearing carrier.
Dave M wrote:On the passenger side, once you've got the hub end out and the center bearing carrier unbolted from the block, the whole axle slides out of the transmission with ease. There's no snap ring on that side as the center bearing mount holds things in place.
Doc Fizzix wrote:For what it is worth, you are doing WAY more work than you need to be doing if you remove the center shaft. All you have to do is remove the drive shaft not the whole thing.
Dave M wrote:Makes oil filter changes REAL easy, too...
algirdas wrote:Isn't there a "square section" split ring on that right side?
Doc Fizzix wrote:Dave M wrote:Makes oil filter changes REAL easy, too...
So do you take the center shaft out every time you change the filter?
Another reason for doing it this way is because if you remove the center shaft with the drive axle the trans-axle fluid will drain out. If you are only removing the right side (as seen from sitting inside the car) then you will not have to drain and then refill the trans-axle fluid if you separate the drive shaft from the center bearing.
algirdas wrote:How hard is it to get the driveshafts to pop off of those split rings? I just want to know how "medieval" I am going to have to get on them.
TheBard wrote:instead of dropping the upper link of the suspension, and having the whole outboard end hanging, he managed it by unfastening the lower end... basically if the instructions said the top he did the bottom, or whatever is the opposite of what is listed in the service manual.
