Steering wheel
Steering wheel
Postby rushing » Fri 08.12.2006, 23:28
Hi :(
can some one please tell me the MEASUREMENTS of a 1990 se turbo lotus elan steering wheel ??. im trying to find the measurements and im having a lot of problems . ive googled it but still no luck.
Aso im thinking of replacing my steering wheel as it looks ancient. can some one please tell me can i replace it with any 32 cm steering wheel which looks sporty???. and how do i do this.????
please advice
thanks
rushing as always
rushing
Postby Oliver » Sat 09.12.2006, 01:49
I`ve been thinking about this as well. Presumably the steering column is Vauxhall / Opel in origin so it`s just a matter of finding out witch one and buying the correct boss kit. You can then fit whatever wheel you like. If anyone has a Momo / Nardi boss part number please divulge !!!
M100 N/A - No PAS
RenautSport Megane 275 Cup
MGF
Benelli 2C
Oliver
steerining wheel
Postby rushing » Sat 09.12.2006, 09:41
hi oliver
im not a mechanic mate infact dont know nothing about it. but some one said i can put any steering wheel on here as mine is a uk spec car and also its just vuaxhall parts after all. what do you mean by the boss kit. please explain. yes i have to replace mine as the steering leather is falling apart. . i was going to retrim but then i though thats more expensive then a steering wheel. thatsthe only mod im going ton do . i dont want the classicness of the car to disappear.
any thoughts by you would be appreciated.
CAN SOME ONE PLEASE TELL ME THE SIZE OF THE STEERING WHEEL IN CM
rushing
rushing
Postby DeeAitch » Sat 09.12.2006, 14:33
The stock SE wheel is 360 mm Dia
Check here for details on how to fit a Momo :D
DeeAitch
Return to Chassis & Steering
