What glue do I use for patching hood material?
Postby mikeydude » Mon 12.02.2007, 18:28
My hood is almost worn through at the top rear (above the right shoulder (it's worn on the other side as well)
I want to patch it on the inside, I tried evostick bit it peals off (I assume it's the water proofing.
Anyone had any luck with adhesives\ glues for patcing up hoods?
mikeydude
Postby Enright » Mon 12.02.2007, 19:27
I just got an old seatbelt offcut from a scrapyard, cut it to length, and used a general purpose adhesive to stick it to the inside between two of the cross-pieces.
Postby paza1 » Mon 12.02.2007, 22:43
I used SETFAST Fabric Glue (which is solvent free) to fix a piece of dark material on the inside of my hood at the wear points (no holes). Worked well but I haven't been out in much rain...
Mark
Silver 1992 SE Turbo.
paza1
Postby mikeydude » Tue 13.02.2007, 12:36
Enright13 wrote:I just got an old seatbelt offcut from a scrapyard, cut it to length, and used a general purpose adhesive to stick it to the inside between two of the cross-pieces.
Good idea, any idea which general purpose glue you used.
mikeydude
Postby theelanman » Tue 13.02.2007, 13:23
mike
I used some kevlar material and some special glue
I use the stuff to repair my dry suit so its pretty good.....
I'll dig the tin out in the next couple of days and let you know its serial number...IIRC it was made by evostik but its the stuckiest most fexible glue Ive ever used
cheers
gareth
ps I think I have some of the kevlar material left......I'll have a look round for it whilst I'm looking for the glue
Postby GeoffSmith » Tue 13.02.2007, 14:21
Purely by chance, came across this.
Gareth, if you've got sufficient material, could I have enough to do my roof please?
Postby WillB » Tue 13.02.2007, 16:09
I do this on a regular basis and use UHU impact adhesive, well recommended!
As for the patch itself, any material that's black, strong construction but quite thin works well. I use to use leather patches but they are a bit thick
It's a good preventitive measure to do this early on
WillB
Postby mikeydude » Tue 13.02.2007, 16:11
Many thanks, I will try it, for the patch I have some actual hood material.
mikeydude
Postby dapinky » Tue 13.02.2007, 17:35
theelanman wrote:I use the stuff to repair my dry suit so its pretty good.....
Bostic 2402 is a 2-part flexible waterproof glue which i use for my drysuit repairs, some of which have now spent hundreds of hours under water without leaking, so it must be pretty good sticky stuff!
(I'm sure Gareths Evostik product must be fairly similar) - It's quite easy to obtain, I got mine from a local hardware store.....they kept it in stock.
Postby mikeydude » Tue 13.02.2007, 18:43
Cheers...I will look for it
mikeydude
Postby theelanman » Tue 13.02.2007, 21:03
dave
it could well be bostic.....I cant remember as it was ages ago I did a load of repairs on about 10 drysuits and theyre all still working with no leaks
cheers
g
Postby muley » Tue 13.02.2007, 22:52
I used fabric adhesive from Wilkinsons - it sticks like **** to a blanket.
For the patches, I cut the palms out of cheap 'riggers gloves' to create a patch of suede.
Postby theelanman » Sun 04.03.2007, 14:20
I have got some trilaminate material that I'll cut to patches and bring with me to Donington for thems who want em........
dont forget to read this to avoid ripping your hood.....its what trim tech gave me when Id had mine fitted
http://www.lotuselancentral.com/forum/v ... php?t=7695
Postby theelanman » Sun 04.03.2007, 15:43
got the glue info.....
BOSTIK 2402 adhesive
BOSTIKURE D10 hardener ref UN2810
cheers
G
the mutz nutz for all you drysuit repairs!!!!! :-D
Postby mikeydude » Sun 04.03.2007, 18:15
Many thanks, I tried again with another contact adhesive and it seems to have worked a bit better..but I will track down the glue all the same
mikeydude
Postby Fubar1764 » Tue 06.03.2007, 06:53
Little late in this discussion, but. . .
3M makes a fantastic adhesive called "Fast Tack Trim Adhesive." Part No. 051135-08031. Very good stuff. I went to the local fabric store and got canvas to patch. How original of me!
-Your "Jack" of all trades
Fubar1764
Postby ShaunM » Tue 15.07.2008, 16:36
theelanman wrote:I have got some trilaminate material that I'll cut to patches and bring with me to Donington for thems who want em........
Hi, Don't suppose you have a small piece left over for me do you :wink: Mine has been patched on the LHS at some point (after a rip), but the driver's side isn't and I'd like to do it as a precaution.
ShaunM
Postby Foo » Tue 15.07.2008, 18:19
Stick-on Leather elbow pads seems to do the job, damned if I can find a supplier for more though...
Foo
Postby The Ref » Wed 16.07.2008, 21:22
Foo wrote:Stick-on Leather elbow pads seems to do the job, damned if I can find a supplier for more though...
I have my own shoe repairer shop i will ask the rep next time he calls if he can order some tins from Bostik.
Billy
There are 3 types of people in the world. Those that can add up and those that can't
The Ref
Location: The "pools" HUFC must win a game some day soon
Postby ShaunM » Sat 09.08.2008, 13:33
I got a piece of canvas from a textile shop (free sample!!!) and super-glued 2 cut circles together before using UHU glue to stick it on. Works a treat.
Tips for anyone doing this: Don't superglue 2 pieces together as I did - the superglue goes hard and leaves a bump in the fabric when the hood is folded, and one thickness of heavy canvas is sufficient.
ShaunM
