TomE wrote:Interested in your comments about ESM chips - guidance on the website suggests it's not compatible with the BBR conversion (FDC issue). Do you know differently?
Monty wrote:Did a trackday at Donny on Sunday, they never did a static test but Donington has one of the most strict drive by noise testing and i never got black flagged
Doug wrote:had you been black flagged then you'd have to find out if it was the noise or just yer driving skills![]()
hope you got good practice in cause you know we'll be checking to see who does the fastest lap come March!
Plus2pete wrote:I had my PECO exhaust fitted a couple of weeks ago at my local Universal tyre and exhaust shop at the knock down price of £30 and it only took 40 minutes. I also had the opportunity to take a good look underneath while the car was up on the lift.
But I digress, last weekend as the weather was nice I took a blast down to Goodwood to get a noise test as I'll be doing the Surrey area track day in May. To my surprise the test came out at 100dB!! I knew it was loud but not that loud!!
I got on to Dave at PECO who was quite surprised and said it would be difficult to fit a second silencer and to his knowledge doesn't know of a muffler to fit an oval tail pipe. Dave is looking into the problem and I'll post his response, but if anyone has any ideas they'd be greatly received.
':oops:'
Plus2pete wrote:But I digress, last weekend as the weather was nice I took a blast down to Goodwood to get a noise test as I'll be doing the Surrey area track day in May. To my surprise the test came out at 100dB!! I knew it was loud but not that loud!!
Noise checks to establish adherence to the relevant limit will be conducted in accordance with current measuring methods as defined by the MSA. Essentially this means that the noise test shall be measured from a position 0.5m behind the exhaust at a 45 degree angle, with the engine running at ¾ maximum revs.
Monty wrote:Now that is loudand i question on how it was tested since TomE is only getting 94dB static at 5250rpm
