Seat Belts
Seat Belts
Postby Specky » Wed 14.03.2007, 13:21
Many thanks to a wise old gentleman called Steve who helped design the M100 seat belt.
The seat belt is bespoke to the Élan due to the internal workings of the retractor... (Technical bit... it a grabber)
The expensive and hard to find piece is the pillar loop...(The company went bust ten years ago). There are only two brand new ones in the world and they are under Steve’s desk. These are to be used as a pattern in case Lotus requires another batch to be manufactured.
The buckle has an alternative which is the twin stalk buckle from the Esprit. ( I don't know how you would fit this though)
If you want a new seat belt assy, lotus have just bought 100...(inside information)
Old number C100U0048F
New number F100U0048F £76:68 + VAT
If you want a new retractor ( Cos the springs weak) there are 50 available in this country and are manufactured by Autoliv Australia..Approx (£25 Each)
If you need a new webbing belt because the dog ate it or just fancy a colour change to one of 70 colours on offer...Approx (£25 Each)..
Faded pink should sort most of you out :smt078
For the future because Lotus has sold out.. Total overhaul is available..
Where to go...
Say hello to Sue at FDTS based in Surrey. They have direct access to AMSAFES parts bin and Steve..
AMSAFE formerly SafeTex formerly Autoliv UK
Ghost wrote:The replacement of the seatbelts is very easy, which is unusual for Lotus!!!
After removing the trim from the 'B' post, a 17mm socket is needed to remove the 4 bolts that hold the seatbelt.
In my case the most difficult job was removing the trim, as my car had been retrimmed with excessive use of black gunky sealant which stuck to everything!!
It took about one hour to remove the original belts, and roughly the same time to install the new belts and refit the trim.
The Autoliv retractors are preloaded with webbing, and F.D.T.S. remove the belt loop that fixes to the 'B' post and fits it onto the new belt before fitting the buckle.
That is the reason I sent my old belts to F.D.T.S., but I suppose you could just send the belt loop and buckle from your old belt.
Postby GeoffSmith » Wed 14.03.2007, 13:33
Nice work Dave. No wonder we couldn't find an alternative!
Postby Enright » Wed 14.03.2007, 13:49
Ah, an old familiar name there.
I used to deal with someone from Autoliv at their site in Havant, Hants.
Might have to do a bit of memory racking to see if I can remember the name.
Who knows, they may have superceded the part with something that's backwards compatible.
Postby Specky » Wed 14.03.2007, 13:54
To quote the words from Highlander
I know his name!!!
Postby paza1 » Wed 14.03.2007, 22:07
Excellent bit of detective work.
:smt023
Mark
Silver 1992 SE Turbo.
paza1
Re: Seat Belts
Postby dapinky » Fri 18.02.2011, 22:24
I'm adding to this (old) thread to avoid the wrath of Enright :lol: :lol:
I suppose that the first bit could have gone into the 'what a twat I am' section, otherwise entitled the 'Not terribly good' thread.......
....but as i then redeemed the situation, i am quite sure that I'm not a twat (but i'm sure someone (or at least 3 i can rely on!) will soon be along to tell me that I am).
Okay, here goes......
Since owning the red elan, every time the car has been layed up for a while, there has been a problem with the seat belts failing to retract, which appears to be a common problem, which has traditionally been remedied by getting a better S/H unit, or finding a new one amongst the pile of Rocking Horse Poo at Donington or Stoneleigh.......
....until Sherlock Speck found a source for the originals......
.....but being a low-paid public sector worker (and being similar in many respects to a ducks backside), not to say, thinking 'how hard can it be to sort that out' and prove THEM all wrong :roll:
Okay, so back to the story, I gained access to the seatbelts by undoing the B post covers, pulled all the bits of crap and doghair out of the mechanism, and gave it a good spray of WD40 (with the belt fully extended, as it wouldn't retract).
Then by winding it in by hand, pulling it out, etc etc etc it freed up enough to make it work :D
Until the next time, when it was all repeated again - in fact it got to the stage where i never actually bothered to secure the B post covers :oops:
Each time, it would work well but would last a shorter time before needing to be re-done - but as it was only a 2 minute job, it didn't worry me. When it got to the stage that i had to 'feed' the belts back in, I knew it was time for another squirt.
And so it went on, until this week when it is time for the car to be used again - no problems with any of the usual suspects (brakes etc), but the seat belts were back to failing to retract - out with the WD40! Job done.
Then i had a thought...... why not try a more permanent remedy, after all, how hard can it be????
The answer is "not at all hard, as long as you follow a few basic principles".
Firstly, the Health & Safety warning/disclaimer.....
....Seat belts are a safety item and legal requirement - if you ain't confident/competent - leave them alone and buy a new one! The process involves some nasty chemicals so only use in a well-ventilated area. There are some sharp bits under tension - go steady.
Okay, if you are confident/competent/too tight to buy a new one, you dont need any special tools.
Firstly, clean the actual belt - if the webbing has got damp (theres always condensation in a UK elan!) it will expand a bit, and may not fully wind in tight enough to fully retract.
I used carb/choke cleaner, but brake cleaner could also work (naptha-based solvents) - it needs to be something which wont degrade the material/stitching. Spray the stuff onto the webbing and allow to evaporate (it won't take long - but don't breath the fumes). it will tighten up the fabric and allow it to settle back nicely.
This may be all that is required in your car.
It will probably help, but may not be enough, so move on to the next stage.
The basic principle of any seat belt (and specifically the elan), is that as you look at it, there are 5 bits to consider - the actual belt material, the bit which grabs the belt in case of excerted inertia, the metal cage/plastic roller, then the 2 plasic boxes on the sides of the cage.
The belt will now be clean and (hopefully), unfrayed - if SLIGHTLY frayed, it will probably be because the mechanism isn't exactly vertical, and the belt edges are rubbing in normal operation - run a blow-lamp up the frayed edge to get rid of stray hairs - dont do it when there is still solvent on the belt, or it will be another elan less on the roads :roll:
If the mechanism isn't allowing the belt to feed freely, it needs re-positioning - a 17mm socket to loosten the bolt, then correctly position it rotationally so that the belt edges don't rub.
Make sure the grabber is clean (carb cleaner again), and moves to grab the belt when you give it a tug.
So far, so good. Now consider the 2 plastic boxes - as you look from the front, the one on the left contains all the bits for the safety mechanism (inertia balls/springs) - DONT TRY TO OPEN IT - you will end up with bits all over the place and it ain't gonna go back together again (I learned that years ago on a different car - luckily i had access to numerous spares). Just give the outer ends of the roller spindle a squirt of silicone/PTFE spray - i have used spray grease with PTFE, and also tried dashboard shine (silicone spray) and both work well. - DONT USE WD40 - it washes the correct grease out and leads to the scenario I started with!!!!!
The right-hand box is the retractor mechanism and the sourse of most problems - this is where you need to be.
Now, if you have never squirted WD40 into the mechanism, (after all, what sort of idiot would do that :roll: ), then the chances are that the moving parts will already be adequately lubricated, but the spring needs a bit more tension after 20 odd years of use. Therefore, you dont need to take it off the cage, or dismantle it at all.
The principle is that there is a large 'clock spring' which tensions up as the roller turns to let the belt out, and the stored energy retracts the belt once it is released. The roller is on a spindle which turns a plastic cog attached to the inside end of the spring - hence the need for silicone lube, not WD40, plastic running against plastic will heat up from friction during operation of the belt and cause it to stick (think headlamp motor bushes).
A bit of extra lube may be all that is required to make it work.
If not, on we go......
Generally, the belt will either not retract at all, go slowly, go in most of the way then stop, need feeding in (or anywhere in between) - all need the same thought process as explained, but some will be fixed without the need to go any further.
Okay, so assuming that it retracts either slowly (should be fixed with a clean belt, or lube), or most likely, goes mostly in but not fully.
The spring needs a bit more tension due to old age.
Pull the belt fully out and hold it out by looping it round the seat or steering wheel - you will see that the roller is white nylon (or some other such plastic), with a slit running through it for the belt - luckily, in Lotus tradition, it is lightened by having lots of cut out bits!!!
with the belt fully out, place a small screwdriver (or similar) in one of the holes and release the tension on the belt to allow the roller to jam the screwdriver against the frame (it isn't hugely tensioned anyway, but you need to keep the tension it has got!). you can now feed the belt through the roller and you will see that the end is just a doubled-over thickness of belt.
You need to cut the end off with a good pair of scissors/shears/knife as close to the end as you can, then pull the belt back so it is off the roller - don't pull from the top, or it may go out through the grabber bit and it can be awkward to re-thread it due to the limited clearance (as required to make it work). you can leave the webbing lying on the floor - it'll only be a minute till you put it back anyway - remember not to twist it - it needs to go back as it came out.
Now add some tension to the spring by taking out the screwdriver and winding the roller a bit tighter using your fingers and/or a couple of screwdrivers - DONT LET IT GO or you'll probabaly have to go to step 5!!!!!
As a guide, it will probably only need a couple of full turns to make a great difference.
For your information, there is enough spring movement between fully unwound to fully wound to give 21 turns of the roller, the seat belt going from fully retracted to fully extended moves the roller 11 full turns (and a bit). My belts both had 16 turns of tension on them when i started.
I turned the rollers 3 full turns (easily achieved with just your fingers) and then stuck the screwdriver back in to hold it.
Feed the webbing back through the slot (there is a right and wrong side - it's obvious when you look at it as one side it wide enough for the double thickness end, and the other is slightly offset to allow for a belt thickness as it winds up) and pull about a couple of foot of webbing to allow working space.
You need to finish the end off so it will not pull out of the roller (obviously!).
I did it with a minimum of tools/expertise, but a knowledge of the mechanics/physics/forces involved.
Simply fold over the end by about 5mm and hold in a clamp (pliers, vice, toolmakes clamp etc). Heat up an old knife with a blowlamp flame (could use a soldering iron I suppose), slip the hot blade between the 2 thicknesses of webbing to melt the ends together (don't get it too hot or allow the material to degrade/weaken) and press together. Tidy up any frayed ends with the hot blade, then pull the webbing back through the roller to seat it properly.
Feed the slack webbing back through the cage so that the belt is fully extended, remove the screwdriver and allow the belt to fully retract like it always used to do/does on other peoples cars!
Marvel at how simple it all was, and why you have put up with it for so long........
.....unless you've been a tw@t and used WD40 - in which case it needs re-lubricating, or clumsy/unlucky and the roller has gone 'twang' and fully unwound, in which case the plastic cog has probably come off the end of the spring.
If you've got this far, then it gets a bit fidly, but is straightforward - it is easiest to do the work on the bench, but that means unthreading the webbing totaly and then taking the cage out (one 17mm bolt).
It is possible with leaving the webbing in, but without special tools (and luck) you'll never get the roller tensioned properly without taking it out anyway (I know - i tried :roll: ).
Okay, so the cage is out and the roller is loose in both directions, that means the spring has come off the cog! If it will still tension up, then it needs lubing - either way, it has to come apart.
Don't think that you can just take the outer cover off with 4 little clips - it don't work!
There are plastic pins which go through the outer, inner and then into the frame, heat expanded to keep them in place :roll:
You need to cut the excess plastic off the inside of the frame with a Stanley knife and/or narrow chisel so that the whole plastic box comes away (it may need a bit of a lever with a screwdriver to seperate it from the frame (because of the plastic pins), and will go twang if the spring is still under tension (which it shouldn't be!).
With the black box (retractor mechanism) seperated, it needs opening up - a bit of careful levering with a small screwdriver, and trimming with a Stanley knife, the outer cover will come off (or in my case, pivot open on one remaining plastic pin).
Be careful here, there isn't much inside, so unlikely to loose anything, but the spring will still be under sone compression tension within the casing - if it flies out then you'll have a couple of meters of coiled sharp edged metal ribbon flying about - common sense says to wear gloves and goggles (I didn't, 'cos i needed dextrity in my fingers!), so take a risk, but don't blame me if you slice a bit out of your finger!
If it flies out, then it is easy enough to get back in, and it is obvious which way it goes, and how it fits into the casing (just remember, put it the right way round so that it winds up when the central cog goes clockwise!).
If it hasn't flown across the garage, then it's a billy bonus, and you just need to wipe up the WD40, and lube all moving plastic surfaces/faces with silicone grease (or I suppose vaselline may do) - but not too much.
Fit the inner cog onto the end of the spring (it will only clip in one way, and if you can't work it out, then this job probably isn't for you!!!)
refit the outer half of the casing, and make sure that it is all working by giving the spline a couple of turns using a screwdriver - it should unwind under its own steam, so don't let it fly, or the cog will come off again :banghead:
Now you know its all working, put it back onto the cage - you may need to 'weld' the two halves together if you've broken the tiny clips using a hot blade again - but i just gave it a bit of a dab with a hot glue gun.
again, keeping the retractor on the frame will need a dab of hot glue on the inside of the plastic pins (not too much, or it will hit the roller).
Take it back out to the car and follow earlier instructions on how to tension the roller and refit the webbing (can be done with the frame fitted in car, or still in your hands, locking it with a screwdriver until webbing is in situ, then fitting it back in - i found that to be easiest, and is no problem as long as it doesn't go twang when handling it - to prevent this, fit the frame to car without any tension on it, then just wind it up and fit the webbing.
Make sure the frame is fitted so that the webbing will retract without rubbing the side of the frame - a couple of degrees out of rotation is enough to mess it all up......
....now you can marvel at how easy it was, and promise yourself never to use WD40 on moving plastic parts again :banghead: :bonk:
And yes, Geoff - I'll put it on the wiki tomorrow :roll:
Re: Seat Belts
Postby superbad » Mon 21.02.2011, 18:37
That's long! I just replaced one side with one of the new, recently manufactured units Lotus has. Pretty easy job, took less than an hour. Not that expensive considering it's a safety critical item.
One thing about WD-40: it's not intended to be much of a lubricant. The "WD" stands for "water displacement"- it's meant to clear out water and condensation from mechanisms and tight spaces, as a way to prevent corrosion. It's mostly solvent with a small amount of mineral oil, which is supposed to leave a rust inhibiting film. Most of it evaporates away pretty quickly, and the mineral oil is not a very good lubricant, which is why you've had to keep redoing this. You might have better luck with a proper spray lubricant.
superbad
Re: Seat Belts
Postby Specky » Mon 21.02.2011, 20:09
When you say recently manufactured.... what year were they made? It's normally on the Lotus packing.
I haven't chatted to Steve for ages who makes them for Lotus, so I'm a little out of the loop.
The first post of the thread says it all really.
Cheers DaPinky for the write up,
as you can guess the Preproduction has a slighty different seatbelt assembly, so I'll see how I get on when I get two minutes to spare.
Re: Seat Belts
Postby superbad » Mon 21.02.2011, 21:10
I didn't get the date off it, but by "recent" I meant from the batch you identified in the original post here. It clearly wasn't late 80s/early 90s stock like so many other parts.
superbad
Re: Seat Belts
Postby Steve A » Mon 21.02.2011, 21:38
:D When it comes to your safety it's not worth messing around :poke:
One of the first things I replaced on my car was both my tired old units, like Specky said speak to the very loverly Sue at FDTS
there service is 2nd to none 8)
Re: Seat Belts
Postby dapinky » Tue 22.02.2011, 08:37
Steve A wrote::D When it comes to your safety it's not worth messing around :poke:
I fully agree - as stated in the write-up, if you don't know what you're doing, leave alone!
This is/was intended for the type of person who is capable of swapping a set of brake calipers, or even swapping the old seat belts for the new ones.
There is no mystery to the job, and it will not compromise any safety if usual care is taken - i was merely trying to explain the work/theory involved.
As stated, the seat belt unit has a variety of parts, all of which work together to stop your face hitting the dashboard - we are only adding tension to the retractor, not interfering with any of the locking mechanism - the procedure above does no more or less (physically) to the whole thing than each time you pull the seat belt out to wear it.
I would NEVER advocate messing with any safety critical items if you don't know what you're doing - but i don't consider this to be any more or less 'safety critical', than tyres, brakes, suspension units or probably most of what is looked at on an MOT - and many on here will happily swap a set of pads, shocks, or even put a spare wheel on to get you home.
Re: Seat Belts
Postby Steve A » Tue 22.02.2011, 16:20
:) Don't get me wrong, I was guilty of messing around with my seat belts,
because I didn't improve matters I decided it just wasn't worth the hassle :wink:
Re: Seat Belts
Postby Sleeka » Tue 21.01.2020, 03:24
I have followed this thread and the online YouTube video in fixing the tension and found my belt was already as tight as it could go (maybe already tightened by previous owner). Both sides need to be better, luckily they're not horrible yet. It seems the Fed model has different seatbelt mechanisms then what I saw in the video.
Does anyone know if they can be rebuilt in the US? There are a few websites that say they rebuild any seatbelt retractor but all three websites had the same address in MA so I am hesitant to trust them (seems fishy).
Or if they can be replaced with new ones? I haven't seen any info on replacements for Fed models unless I missed it in my searches.
Sleeka
Re: Seat Belts
Postby Sleeka » Thu 23.01.2020, 18:33
No one has had to fix or replace their seatbelt retractors in the US???
Sleeka
Re: Seat Belts
Postby david924s » Fri 24.01.2020, 08:19
Not sure about getting them repaired in the US, but you can buy a replacement unit from SJS for around £95 including P&P and vat or at least in the UK you can.
I have just bought a secondhand one from another Elan as my passenger one has been pulled out too far and won't retract at all locked! It was always poor to retract anyway but it seems broken now, will hopefully get it out soon to see if it can be released and then re-tensioned and if it can't I have a good spare to go in it's place.
It might just be cheaper and easier unless you want originality to buy some universal units including retractor, belts etc. and replace the whole lot, in the UK you can get universal units for kit cars etc for around £50
david924s
Re: Seat Belts
Postby rip » Sun 26.01.2020, 16:03
Sleeka wrote:No one has had to fix or replace their seatbelt retractors in the US???
Be patient. You only gave it 2 days for a reply.
This site is nowhere near as active as it used to be. Many still contribute on here, but less frequently than they used to.
Re: Seat Belts
Postby tigerdog » Sun 02.02.2020, 16:25
I haven't replaced or tightened mine (yet) but one thing comes to mind. I drive a lot of new rental cars, but have the Elan and a 21 year old BMW as my personal drivers. The seat belts in the old cars are just... stiff. As if years of dirt, oils and general mung stiffen the nylon, compared to nice new supple ones. Has anyone tried pulling the belts out fully, then cleaning them thoroughly with warm water, soap, etc., and finish by sucking the residue out with a shop vac? If the belts were more supple, seems like they'd retract more easily with the same force applied by the mechanism.
