Any idea where this wire goes??
Postby vowler » Sat 15.12.2007, 16:42
I took both radiators, cooling fans and everything off the front... replaced everything and then found this wire with a 90 degree connector on it. It was a long time ago that I dismantled everything and can't remember this wire at all!! Anyone got any ideas where it goes... or what it is for? The car is LHD with air conditioning... Cheers Vowler
vowler
Postby Dico » Sat 15.12.2007, 17:47
I'm 99% sure its off your power steering pump.
It will work fine without it though (i've done around 5000 miles without mine connected), I snapped the piece it attatches to when I was putting tension on the power steering belt :?
I think it is supposed to increase the revs (or something) when you are turning at low speeds, to avoid stalling.
Although I could be completely wrong :-)
Look up in the air (from underneath) at the power steering pump. You should see a little nipple type thing that it attatches to.
When I did mine I coukd see a big nipple type thing. But that turned out to be Monty.
Infact i'm 100% sure thats what it is.
If it isn't, i'll eat my exhaust :P
Looks nice and tidy under there by the way ;-)
Postby vowler » Sun 16.12.2007, 17:06
Thanks for your prompt advice Dico... I'm sure you are right... I'll check in a couple of days.. when I can get under it!! Thanks again Vowler
vowler
Postby Candles » Mon 17.12.2007, 20:42
I agree with Dico!
Candles
Postby SGSR » Tue 18.12.2007, 01:22
:agree: i just tried to drain my collant system to put in some antifreeze for the cold weather (Guy i bought the car from hadnt put any in :evil: ) and i saw something very similar attached to the power steering stuff.
SGSR
Postby rip » Tue 18.12.2007, 09:23
Dico wrote:When I did mine I coukd see a big nipple type thing. But that turned out to be Monty.
I couldn't see anything like that from under mine.
Postby vowler » Tue 18.12.2007, 20:19
offending wire re attached!! Thanks guys.. you sure know your stuff!! Vowler
vowler
Return to Chassis & Steering
