Track Rod End Dust cover
Postby Bern » Tue 19.11.2019, 17:49
Is it possible to get just the dust cover for the track rod end? I split one when I removed the track rod from the steering arm to check the rack.
'90 Elan SE
'95 MGF
'16 Renault Zoe
'03 VW Transporter
'72 Land Rover 88
'80ish Kubota B5100E
Bern
Re: Track Rod End Dust cover
Postby Rambo » Tue 19.11.2019, 20:06
Fairly sure you could get them from SJS or Chris. Neil at one time
Postby dapinky » Tue 19.11.2019, 20:26
Bern,
I used a universal item from Ebay - size 'medium' IIRC. I bought a few a number of years ago, and (as it happens) I used my last one this week for the VW van.
I must get some more!
SJs will no doubt be able to sell you one, but with their P&P pricing structure, it will be far cheaper to source one elsewhere (unless you are getting other things as well).
The 3 measurements you need to know are the diameter of the small hole, the diameter of the big hole and the height of the rubber..... then find one to match. (There is nowt special about the Lotus ones).
Postby Bern » Tue 19.11.2019, 21:06
Thanks chaps, I had a look on the SJS site, couldn't see any.
I'll take Dave's advice, measure and then order some from eBay.
'90 Elan SE
'95 MGF
'16 Renault Zoe
'03 VW Transporter
'72 Land Rover 88
Bern
Return to Chassis & Steering
