Monty wrote:Just wonder if the new rack that was fitted was for the S2![]()
Normally i would say replace the lower UJ but would imagine they would of fitted a new onealso wonder if they fitted the UJ correctly as per the service manual
Specky wrote:Why was it all changed?
Was it an accident... did it partially collapse the steering column?
Specky wrote:If it was... the steering column is designed to collapse in an accident, sadly the tell tale sign is stiff steering.
All is not lost though,
There must be a dimension check and Lotus are doing the steering column bits quite cheap at the moment.
If you need any help just ask away.
welcome to the LEC Specky wrote:I'll read the manual and see what it says.
I've got some steering stuff arriving from Lotus as we speak, possibly tomorrow.
I've also got another steering column in the garage (pottentially damaged with the same issue)
Tomorrow I'll try and come up with a place to take measurements...
Finally,welcome to the LEC
Specky wrote:Good news,
the dimensions are in the manual.
I'll PM you
Jackonicko wrote:The very good news is that inner steering columns can be had for peanuts from aftersales. Lower UJs are common with the Land Rover and are £12 or so.
Where are you located?
speed-demon wrote:This is the Medina press car isn't it?
I saw it advertised with 17" rims...
